I heard that the old clip style ones were illegal as they protruded from the bonnet too much, but eh flush ones are ok?
just read the regs and yeah I think your right.
(last time I read was 10 years ago for my stang)
if they don't protrude your ok so the aero catch ones should be fine..
well unless a cop decided they are a pedestrian hazard.
so regs say:
  • Like 1
im keeping my stock latch + flat bonnet pins just for safety.
read something the other day of someone in Aus, those black flat bonnet pins stripped the thread on a racetrack straight, bonnet flew up and bent the roof :wacko:
Hmmm true true, but it's jsut a pain in the ass to have to unlock the pins, then pull the bonnet latch. Was hoping to remove catch all together so it's just a straight process of undoing pins. Not wanting to get defected for it though so thought 'd see if anyone has any info regarding
Need two secure points for the bonnet if you ever do any track days
Sorry for the noob question but what does that mean? I've got 2 bonnet pins on either side of the bonnet, but that's not what you mean is it? lol
Edited by T.D
i love the people that go on about Reps being deadly...
If half the national comp level drifters can use them and hit ripple strips sideways at 200kph without issues, somehow I doubt some phaggot in a VW doing 3kph to get up a wooden plank into shallow driveway to go to a circlejerk hardpark meet has anything to worry about
  • Like 3
yeah 2 bonnet pins is 2 separate anchor points.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
