Wasn't that after giving themselves a massive pay rise? While at the same time telling paramedics they don't deserve a pay rise?
Then there's the fact they get a ridiculous pension when they're finished, regardless of if they did any good or not...
And no one told them to be cocksuckers, they chose to be politicians... Everyone hates union tradies but that doesn't get me any more money
Hey man give paramedics a pay rise, and police, fire fighters give anyone a pay rise thats cool - just remember YOU pay there pay rise through higher taxes, your cool with being taxed more right ?
Easy... It is quicker and cheaper than driving AND involves less walking
yeah for me i've gotta walk like 25 mins, +25 min on train..(each way) i wouldn't usually care but it's f*kn cold in winter lol
on the plus side i'm walking about 4km a day which is nice
Edited by UNR33L
No linkedin poachers for me, just endless video production companies / printers / graphic design mobs wanting me to "touch base" with them because there could be "synergy" between our companies.
How about my fist touches base with your face and creates some synergy between your head and the ground
#sickofsalespeople
dem linkedin poachers lol
anyone else on linkedin and fairly often getting adds from recruiters to discuss 'new opportunities'? seems like it's just increasing over the last couple of years no need for seek anymore
I get them calling all the time. not so much add's
they call the main switch and try and get transferred through, all office manager was great at off loading them.
get enough offers with out linkedin.
and 1 min after that posted one emailed me but trying to sell a candidate not recruit me..
Adam Goodes in the media again, doing what he does best...
f**king what NOW?
edit: "Sydney's Adam Goodes has no idea why he is often booed when he plays in Melbourne"
BECAUSE YOU ARE A FLOG!
He is routinely booed at the footy and came out saying he has "no idea" why.
The news articles were suggesting it was due to him being indigenous, whilst swiftly dismissing an entire list the authors themselves created, detailing why he's in fact just a f**king flog
“I don’t simply want to be remembered for just kicking around a footy,” Goodes, 34, said in an interview for this week’sSunday Telegraph MadFit column
Don't think there's much risk of that happening Adam
my facebook account has been locked and they require me to send proof of ID. wtf? the only thing i can think of is that i dissed some unknown Candian rapper on his facebook page and that he reported me. I cant find any info on google, just a bunch of Indians and Bangladeshis asking "my friends account has been locked..." yeah bullshit, working on a facebook farm will do that.
speaking of facebook farms and India/Bangladesh... its not surprise there are hundreds of people on linkedin in engineering commenting on posts from major companies saying "I will enjoy working on such a project, if given a chance." and "please check my profile"
(^ direct quotes)
  • Like 1
f**king what NOW?
A travesty he won Australian of the year. No way he won it for any other reason than being indigenous
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
