Birds I think I just found your Christmas pressie.
http://hellogiggles.com/feminist-coloring-book/2/#read
Why have I never met an attractive feminist?
Are they ugly because they are feminists or are they feminists because they are ugly? Chicken or the egg...
JUST had a customer turn up.
the flamin mongrel was so hipster i was expecting hamish to fire a scud missile on the flamin mongrel.
patchy beard- check
thick rimmed glasses- check
gay haircut- check
short shorts from 1943- check
gay shirt- check
crocs- check
just when i thought this flamin mongrel couldnt get any queerer.
he rolls a ciggarette and lights it up using matches, after failing a couple of times.
doesnt use lighters because theyre too mainstream
I'll just take cash.
Vietnam seems too much like Bali..?
+1 Vietnam, its not a party-place like Bali.
I was celebrating NYE in Hanoi, Police came into club (disrespected my family) & shut it down at 11pm. No place was open past 11pm on NYE.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
