Birds I think I just found your Christmas pressie.
http://hellogiggles.com/feminist-coloring-book/2/#read
Why have I never met an attractive feminist?
Are they ugly because they are feminists or are they feminists because they are ugly? Chicken or the egg...
JUST had a customer turn up.
the flamin mongrel was so hipster i was expecting hamish to fire a scud missile on the flamin mongrel.
patchy beard- check
thick rimmed glasses- check
gay haircut- check
short shorts from 1943- check
gay shirt- check
crocs- check
just when i thought this flamin mongrel couldnt get any queerer.
he rolls a ciggarette and lights it up using matches, after failing a couple of times.
doesnt use lighters because theyre too mainstream
I'll just take cash.
Vietnam seems too much like Bali..?
+1 Vietnam, its not a party-place like Bali.
I was celebrating NYE in Hanoi, Police came into club (disrespected my family) & shut it down at 11pm. No place was open past 11pm on NYE.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
