Dezz to the left of me, Ric and Alex to the right
Here I am
Stuck in the middle with Hamish
Don't think people didn't notice you calling Dezz a clown, and Ric & Alex Jokers
Unless the centre is 60kms to the left hamish is not located in the centre.
I suspect he votes greens.
Christ no... I work in a bank dude
Hamish is so left the Greens vote for him
FKN LOL
Just for everyone's entertainment, I went back to the 2013 Fed Election Vote Compass...
It's roughly what i would have expected....
Now I wanna see Alex's results (if the chart goes that far)
Dezz when you went to Broadford is there a few different track layouts?
Ended up getting some leather pants too figured may as well if I get into it a bit.
Got PI on Sep 11 too
thats racist.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
