We've been friends since we were 5 years old. Couldn't do it.
so? you aint friends no more..
man if a girl did that to me knowing full well im in love with her, i would make sure she would become the most jealous person alive..
She just wanted to be friends for the time being until she felt she wanted more again.... I thought the best move would be to end it entirely and then she'd miss me / become jealous of me going out heaps with mates.
Alvin: Never had Wagyu before :(
i've got wagyu if you want some brah.
ill be there on the weekend, cousins want a hit too.. how much sms me.
fair enough. still. mind f**k her.
if you want, i can cook you a steak now.
lol i've got two blocks, so if you want those, i'll pick them up tmr. they're not huge, so probably cheap.
Didn't you read the BB thread...if she dumps you for no good reason, it's a slim chance she's gonna get jealous and want to be with you again...otherwise she wouldn't have dumped you in the first place. If you're after revenge, all you can really do is make it known that she was easy to get over by getting with someone else. But really, the best thing you can do, whether you want her back or not, is try to move on. That way if she doesn't come back you've still got a head start on life without her.
Good move either way. It's prolly not what you want to hear, and this is just an assumption cause I don't know the specifics of your relationship/breakup, but the "temporary" break from a relationship is often an excuse to legitimise cheating / playing the field. If it doesn't work out, girl can go back to original boy. So really, the best thing you can do for both of you is move on. There's always that chance she might re-appreciate the relationship...but it's very slim...and do you really want to be with someone whose feelings come and go like that? You made the right choice brah :)
P.S. the exes that I stayed friends with, I did so because of realisation that the part I would miss most about the relationship was the good friendship. So something to consider I guess. You don't just lose a lover in a break up, you lose your best friend too. If you can stand being friends and overcoming feelings or that person being with someone else, it can be very rewarding to have your old friendship back. Don't fool yourself though, only stay friends if you can keep it in constant mind that you're never getting back together...or it will be torture. Bit different for me cause I'd only been dating them for a short while versus your 4+ years.
/lovelinesaustralia
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
