Alvin, any luck with grad positions?
Got nothing from my end..... :unsure:
This is why I like to ask people how and why it works, just for the lolz. hahaha
unfortunately, i've been as demoralised as it gets, so i haven't been applying as much as i should,
though really, advice from my research project supervisor is to document my gold extraction, put it into a mini report, and slap that along with my CV. but i'm really cbf about that, housemates are annoying.
also, linkedin, yes or no?
though, i'm really supposed to apply to technip and santos. mate works at santos, he might be able to do something. but applications have to wait though, gotta finish all these assignments and tests first.
mini report about your research slapped with your CV might actually be a good idea!
Did mine on otimization of an intrusion beam on the vechle's side door implementing composites, would've had Ford using the design if only the composite was strong enough.... maybe Ford wouldn't have been in such a bad position if they had used my lighter composite side intrusion beam lol
linkedin, not sure myself. It's good for networking like fb but corporate side of business I suppose.
Get onto technip and santos! Connections will bring you along way in the engineering field atm, might be your only hope tbh.
MY GOD
dude, seriously.... you need to either live by yourself or research your housemates more BEFORE moving in with them
nah, its more like, human curiousity annoys me.
and settle down mr chef,
every single time, i open my leaching vessel, which is really a 5L ice cream box filled with copper chloride, i get asked the same questions, every single time.
1. what is that? (copper chloride)
2. what does it do? (dissolve copper via electron transfer oxidation)
3. why are you doing it? (to dissolve the copper base metal layer, liberating the gold plate on the gold connection points)
4. you sure it works? (well, that's what i'm trying to find out)
its been asked at least 4 times to the point, that i really cant be f**ked doing anything when people are around. which is really why i do not like ignorant business students very much. sif not have at least some high school chemistry knowledge
and i also do not like idle banter because conversations with jason is shallow as f**k. but i cant filter acid in my room either, so i'm just letting it settle outside. yes, there's at least 1g of gold flakes sitting around in the front porch.
i'm sure networking through linkedin would get us somewhere too, but yeah, as soon as i finish all these assignments due all at the same time.
and a massive control systems test on tuesday, dafuq's fuzzy logic again?
linked in is great for getting jobs,
All the requiters that call me have got my details from there.
make sure you join some relevant groups to the jobs you looking for as that shows your interest and such and they can see this.
Sir yes sir,
Got to get on that shiz then.
If you get a job at Santos I can see you making over $100k a year easy
Guest
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
