dw, fifo ymcmb
you can afford it
bahahaha
Lol what good is more money when you waste it. End up in the same spot :P
Received email from telco confirming our discussion. Says to contact if any questions. Is there any more I can ask for or game over?
Maybe a payment plan if you want to piss them off :D
Did you end up going the solar panel route?
Just got 5kw system done to our house. Was around 6.5k? Not bad
House next door has a 2.5kw and says its not enough, they're 60-70yo couple. But I dont know how they use their power
Parents got one at their house... Bills have reduced a fair bit I believe, will pay itself off eventually but not sure when... If the Govt. keep the feed-in rebates up past 2016 it'll pay itself off sooner
My parents just got 8kw system, will see how the next bill. Got it for 8k with a supposedly free ipad mini or $300 cash back... dad asked for the ipad mini thinking it'll be cool. -__-
Still waiting for the first bill to see what difference.
LOL. You probably bought it from the company my mum got it from. Hahahahahahahaha. Was the sales man a viet lad?
Mum took the 300 off.
Shieeeet. Our roof aint big enough for 8kw. Hopefully 5kw is enough for us
Guest
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
