No, I prefer to get irrationally angry at people who get nostalgia about things that are 'silly new things that little kids are into'
Like Pokémon.
How dare this forum autocorrect and add that little thing above the E.
stupid nostalgic forum
Pokemon is the goddamn bomb.
And going strong; this was just announced:
Originals were of course, awesome. I loved GSC too, felt pretty much like the originals to me.
After that is what I started to consider new gens... but I still play each new gen when it comes out, SO GOOD.
youth5eva
por que no los dos ... something something:
ur fav plattsy :ninja:
you know i would have to pick the last one just because its the only one not photoshopped...
stupid new age kids photoshopping everything got no idea of real beauty anymore
then again that all started when bitches started wearing make up...
Speaking of Lego, friend linked me this the other day:
http://www.amazon.com/exec/obidos/ASIN/B00HX14C7Q/ozba0e-20
And yeah, the Death Star in lego always looks impressive.
True dat at expense; yet I saw people had limited edition Millenium Falcons which cost around $600, now going for like $3000 (some guy sold his used set for $2500 lels).
You mean that my falcon is worth a shitload more than what I paid?!
I'm sure you'd bang them all though :P
Guest
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
