Calder was pretty crap last night, got there at like 7 and only got 2 runs until 12.. (with a small dinner break).. around 300 cars there. First run was complete shait, left it in full auto performance mode with traction control off and span 1st 2nd 3rd off the line drifting next to the wall with a 2.7 60ft just let off.. 2nd run was a bit better 13.2 but hit limiter in 1st to 2nd which would of cost me that 12.
Until next time! will definitely be heathcote though. Less cars ftw. Probably enter in that tri battle thing - Ash you going??
Also met Grant down there in his R with a slipping clutch from looks of things :P
Not bad straight out the box!
Yeah pretty quick for stock I guess, I know it has 12 potential but just need more than 2 runs in my GTR I had like 10-12 runs and the last run was the quickest pretty much gained .3-.4 sec over the day. Probably should of taken some air out of the 19s and got rid of spare tyre but cbfed also had like halfa tank of fuel. Really want to get into the 12s at the SAU tri battle now :D
lol yeah that's fair quick for a standard car. Should get a sticker that says "bought not built" :D
Haha, the car would probably get keyed by a holden driver. I must admit its good not worrying about cops. I even did a few laps of prinny last night with racing numbers all over the car and burnt rubber on the rear guards.
Still not happy on the fact that fancy ford with warranty and reversing camera is faster than the mighty mythical japanese creature... tongue.gif
Time to whack Nismo Coppermix twin and milk some more power out of this thing. Smelt some burning on way home but no slippage, should be fine if I simply potter around the town.
Guest
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
