Hi Guys,
I serviced our M35 yesterday and discovered the top tank on the radiator has started to leak around the crimp seal, i don't think the tank's split though and will take the opportunity to do an overhaul on the cooling system with summer coming up.
My question is around the parts i'll need to do this;
Radiator - I believe that a standard V35 radiator will fit with little to no modding required, can anyone confirm this?
Thermostat - Again I've read the OEM VQ35 thermostat is the same and will run with this unless there's a better option.
Hoses - Thought i'd do the hoses (radiator, heater, etc) at the same time but i can't find any listings for these, are they the same as a V35, Z33 or is something else compatible?
Coolant - do we use the green or red coolant in our M35's? There's green in it from the compliance workshop at the moment but possibly because that's the cheapest, not the best!??!
Any advice you guys can offer would be awesome, thanks in advance,
Jas
https://www.sau.com.au/forums/topic/381027-m35-cooling-system-overhaul/
  • Replies 48
i have a 3.5L V35 radiator in mine, needed some cutting but it fit in fine. apparently the 2.5L models go straight in. a Z33 radiator will NOT fit correctly as the cap is in the wrong spot. but physically it will fit in.
VQ35 thermostat is the same, its not a big job to change, just fiddly with one of the bolt locations.
the hoses AFAIK are the same as a Z33/V35, and we use green coolant. ive been using nulon stuff in mine for ages, havent had a problem
Yup, as Iain said.
V35/G35 aftermarket radiator will fit but will need to cut the surrounds (take heed that the cap is on our drivers side of the tank)
Nismo VQ35 thermostat will serve you well
Z33/V35/G35 radiator hoses are the same as ours.
Green coolant
Job complete!
Thanks again for the info guys, i ended up going with a radiator from Fenix Radiators and used the NIS1631A for $330 delivered the next day, great guys to deal with and would use them again for sure.
For those looking to do the same, a few pointers when using a V35 radiator;
This is slightly larger than stock, it's a little higher (only mm's) and wider and consequently the radiator support and the top and bottom needs to be trimmed on the passenger side only. Not hard, just a hit with a dremel and you're done
Because it's wider than stock, the fan shroud needs to be trimmed to sit flush against the radiator again, just trim off the sides where this used to wrap around the stock radiator.
The extra height means you need to trim the bottom off the two locking "mounting brackets" (it's what the G35 ,manual calls them!) so they can be locked down again (the two at the top that you twist to release the radiator).
At the bottom of the radiator where the air con condenser slots into the radiator, there are two slots that need to be dremelled slightly larger, about 1-2mm.
You may want to cable tie the bottom of the fan shroud to the radiator to keep it in place as the OEM radiator has two round holes to secure this and the replacement has two slots, again not a big deal.
Also remember to scavenge the rubber mounts (top and bottom) from the old radiator and the two captive nuts at the top of the radiator, you'll need to reuse these.
Bleeding the system was a straight forward process, follow the G35 procedure in the workshop manual and you really can't go wrong.
Hope that helps others that want to attempt this job and if anyone has any questions fell free to ask away!
Jas
Job complete!
Jas
Nice work!
One question; the link you've provided, lists the price at $462. Where did you source the radiator from?
Cheers, Dale.
Nice work!
Cheers, Dale.
Fenix Radiators also have an eBay store but i called their retail store and mentioned the eBay listing just to see if they were the same company and they just did it for the eBay price, i didn't even ask for it cheaper!
  • 5 months later...
This seems like as good a place as any to ask my question.
I've drained the radiator & bought Nulon concentrated coolant, the one that 1L makes up to 3L etc. What's the general consensus of filling the cooling system with straight concentrate, ie not adding demineralised water? No benefit & a waste of money or good idea & works better?
Cheers, Leon.
PS - where's those install pics Jas? :)
Cheers, Leon.
Definitely don't run the concentrate straight; it's designed to be mixed with water. Glycol is nowhere near as efficient as water for heat transfer; so I always mix it at the leanest concentration; this is when it is at it's most efficient, and still able to stop corrosion & lubricate water pump seals etc.
If you spend time in snowy areas; by all means mix it stronger as recommended; but be aware; it doesn't transfer heat as efficiently. Although I don't think you'll have too much trouble with snow in Byron anytime soon Leon.
Also highly recommend using distilled or demineralised water as your make up water. Just don't drink demineralised water; it'll make you sick.
Being in Byron, and having a snowflakes chance in Hell of actually reaching below 0 degrees, you can ditch the anti-freeze altogether, and use one of those fancy water wetting agents I've seen around. They reckon they work ok, and provide some benefits. I think redline or royal purple make some of them. Have a search- some race car teams use them as well. Because Racecar....
The only issue with Redline "Water Wetter" and most of the others; is that they require regular topping up; more often than Glycol based coolants.
I've used the Redline one on a marginal cooling; it wasn't that impressive; certainly nothing like the 10 odd degrees they claim.
Why do they require topping up? Do they evaporate, when Glycol has some anti-evaporative properties?
Thats interesting.
I'll be receiving a Radiator soon, and a Nismo Thermostat. Hope to keep my temps down a bit.
Edit. Just actually used my brain :P , whenever you drop coolant on the garage floor, shit takes forever to evaporate, so I guess I answered my own question.
Edited by PN-Mad
Thanks guys; consensus is mix as recommended (or a little less) for best cooling performance.
Never heard of demineralised water making you sick if you drink it, but did a quick search & sure enough the W.H.O agrees. Will drink the green Nulon stuff instead.
Yeah, among other things demineralized water will absorb minerals from your body and then wash them out when you whizz. Not ideal lol.
Nulon coolant with it's magical green ingredient should fill all your dietary requirements :P
I just bought one of these after seeing the quality first hand. I damaged my Mishimoto unfortunately so i'm going back to the stock setup for a while.
http://www.ebay.com.au/itm/190638505278?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1906wt_1159
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
