couldn't get the car/stock market thingy to work. Put all money into Maibatsu stock, bought rpg's went and blew up a whole heap of cars.
was just letting myself get killed by police, then would walk out the hospital and do it all again.
did that a few times, 0 change in stock value
Game is so good.
Don't know about you guys but I've got heaps of cash, Doing missions and buying stocks,
I've just cracked 10m on one of my characters. About 40% in. Don't know how I'm going to make 150m for the expensive properties though...
Just got myself a copy from JB $78.00
Awesome sauce!
Can't wait to plug in the new PS3 and this be the first game I load up
its an 8 gig install apparently.... could take a while yet
I've got about 5 million total after what I've spent on property,cars,drugs,hookers lol.
Show me your cars
Daily :)
Mountain runs :yes: rollcage,turbo, all the good shit, xenon light,brakes,suspension
Cruiser :P
I hope online we can race each other through the mountains,
  • Like 1
anyone found any hidden shit yet?
Havent found anything exciting yet :(
I just cant get over how I can explore almost every property and balcony or hydro dam...
Wish I was playing right now, stupid work...
so it appears we have a skylines australia crew..... anyone init?
its called SkylinesAustralia.
tag is SKAU
you need a rockstar social club profile if you dont have one...
join up. im in....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
