The wastegate does stick at a certain spot, but stao assumes me that that it won't open to the point where it jams when the actuator isn't connected.
It's holding boost very very well, it only dips in the last few hundred rpm like they all do, I'm just super annoyed that it wouldnt do it on the dyno. So now I've got a rock solid 14psi map and a turbo that makes 18-21psi depending on temperature. I'm guessing this is the same problem I had when the engine blew up. Got a tune done, turbo decided to work for a day and without a knock map it shat itself.
  • Replies 886
The boost level is not greatly affected by surrounding temp as it is pressure regulated. A increase in boost normally respond to changes in back pressure, means the turbo some how breath more freely. Or maybe a vacuum hose split?
I have offered exchange for upgrade or alteration now and before, during and after the engine rebuild, I don't know the reason of been so reluctant to do so. If there is a genuine believe of a part not functioning correctly then the usual act would be contact your supplier and get it sorted. I can give you a g2.5 for exchange taken out from my own car which has been tested. Check out results at dyno section and see if that is what you are after.
the problem is that i cant have the car off the road for the length of time required to pull the turbo off and send it down then wait for the arrival of the new turbo, my baby is due soon and i need my car. i messaged you about me paying a deposit so you could send me the new turbo first so i could just do a quick change over but never got a response. and what if i send my turbo down and then the new turbo has all the same problems, what am i supposed to do then? either way i lose out.
My bad I didn't saw your reply. I've replied to your email and that arrangement is fine.
If the same problem persists with a new turbo which has already been tested then the issue is not turbo related, or at least you know its not turbo related. And it will be very little that I can help you with in terms of a car issue.
You can take your car to DVS or Toshi after installation whom has a fair understanding of the RB25det engines.
Ok so I've installed my boost control (read exhaust restrictor) and have got it back down to a steady 15psi. My question is. What is wrong with my tune? It's now surging rather badly.
And don't say it's because of my exhaust because it's not. My assumption is that it's over fueling and fouling the plugs, does that sound about right?
Edited by lilcrash
It's not actually a boost control. Just fixed my exhaust. I usually run a pair of twin 3 inch pipes from just after the wheel. I re installed the hks hi power and it has created enough restriction to drop the boost.
The boost is very stable, it just surges, it's doing what I thought was the knock maps were with the other exhaust, that's why I'm wondering if my plugs are just fouling.
Plugs look good, gapped at .8.
What has surge got to do with fouled plugs? Fouled plugs will make it misfire, which is inherently different from surging. It was tuned for 14psi yes? To me it sounds like your tuner has set up the TP cut just above what it was tuned for, but I'm really just speculating given your description.
I made them myself, so make an offer, I think they cost me about $30. They only replace the hks rear section.
Well I do have some issues that I think are wheel related so I might look into that, I need to find some steel rims that will fit.
Edited by lilcrash
the original tune was with them. there is something else wrong, its starting to stall when i take off, blowing excessive smoke and using a lot more fuel. i should have known it wouldn't just work like a normal car. when nissan make a dodgy car they do it well. the whole time ive had the stagea its never not had something wrong.
Don't blame Nissan. Blame yourself for modifying it.
the car is a 99? it's had 13 years of whatever people wanna do to it, not nissans fault! as the certifier/engineers that did my car said most the nissans are on about their 4th bastardiser!, if you have a later nissan with a cvt and a stretched timing chain etc you can probably comnplain a bit!haha
I'll be up your way soon if you want to meet up and compare stuff
i've only got 1 tiny issue with mine so it would be good to compare to (reasonably stock)
are you running stock brakes still? because option1garage do 17 inch steel wheels, they won't clear 4 pots but should clear stock brakes
http://www.boostcruising.com.au/forums/index.php?showtopic=789275
that only lists 16's and im pretty sure they were only $100ish/rim on the pre-buy
maybe check out JPP (http://www.japaneseperformance.com.au/) and see what they can do too
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
