  • Replies 886
I think you miss understood what I was saying, I purchase my car 5years ago in stock form, there has been nothing but problems since. I don't think there is many stock parts left to replace.
WARNING - CSH about to begin.
There is a guy on another forum.
He has an R31 GTSX.
He has millions of spares including 2 x GTSR manifolds.
Anyway..
he had this issue with a missfire.
he replaced the coils, spark plugs, vacuum lines, fuel pump, injector seals, filters etc etc.
spent months
Then went to try a different ECU.
The ECU he tried didn't work
Plugged his old ECU back in.
On the drive home, car worked like it was from the showroom.
Basically, he had dust or some sort of crap in either the loom plug or ECU plug.
the removal of the ecu, then plugging in another then the original cleaned the pin enough for it to stop f**king up.
point of my story is it could be something very simple giving you your head aches.
something you haven't touched.
Engine has been rebuilt.
can't be that (well unlikely)
What has not been changed?
Did you get new silicon hoses for the intercooler?
have you made a simple tester to find any air leaks (mountain bike tube, hand pump and 10 minutes of your time can do this)
what is the ECU? have you cleaned the connectors with electrical contact cleaner?
AFM? (cleaned? resoldered? tried a known working one?)
coil packs?
fuel filter?
fuel pump rewired to get full voltage full time?
air intake sucking closed?
oxygen sensor f**ked?
Cat convertor functional? (remove cat and cat back and test drive (bit loud))
to be honest I can't remember what you have and haven't tried cause it's been going for so long now.
All I have replaced about half of my joins, I'm in the process of doing the rest just ran out of hose.
Yeah I made a tester at work with a built in guage.
Nistune. Il clean them when I get a spare couple of minutes.
Brand new z32 afm
Splitfires
New filter
Walbro hard wired
3inch steel intake with an apexi pod
I think I might try the o2 sensor next
It's a gutted cat. But as said earlier it's got a hks cat back so it is restrictive.
I think the exhaust is just masking the real problem, you shouldn't be having boost control issues just because you have a free-flowing exhaust. The surge issue is different though, have you checked where your TP cut has been set to?
The boost issue was from exhaust restriction, what else or other mufflers do you have in the exhaust pipe? have you ever tried a dyno run with the exhaust dropped off before the cat? if you are making 230rwkws now on 14psi then I don't think you should have an issue doing 250rwkws at 18psi.
Running rough with black smoke and flooded spark plugs is not a definition for compressor surging. its got some thing to do with injection, AFM and ignition. Its freaks me out as you can give any thing that goes wrong with you car a name that links to the turbocharger.
I have a Nistune license, I can't give to you but if you wish to send me your tune file and tell me the part of the data you wish to change, then I can have that changed for you and return the updated file. How ever I'm not responsible if what ever I've asked to change makes the situation worse.
Stao - sorry if you miss understood, I'm not saying it's turbo related. The boost is sitting very stable at 14/15psi constantly, the car just feels like it pulls then doesn't then pulls again. As if I'm opening and closing the throttle. It's a really strange feeling, but now that I think about it it's only been since I installed the front shaft, I will do the diagnostic to turn off the 4wd and see if it still does it, maybe there is just too much driveline for my tune to handle. It's very hard to diagnose a particular issue when you have 2 other problems at the same time.
Yeah I've been keeping my eye out for something but I've also gotta have the cash for tyres, as said above I'm due for a new set anyway. I'm almost tempted to just find a brand new set, like all I need is a cheap rim/tyre combo in a 17x8 +6 or 17x9 +30. It's a pretty common size.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
