  • Replies 886
no you don't
Absolutely do, I recon id get even down to 8.5-9 on a highway. Its tuned quite lean at cruise, as far as it can without being dangerous. Down side i can only use 98+ octane fuel. But even if i drive hard in traffic i get about 11-12 :-)
Alot of WOT and the fuel goes down as the speedo goes up lol
is your car stock std?
other than a complete std r33 with a tuneable ECU could you get 11-12 driving it hard in traffic..., unless your not driving it hard at all...
$1500 trade in value... wtf..?
thats pretty darn crap... strip it for parts
Did you turn O2 feedback off and lean it out at cruise? If you did that I could believe it, but with stock O2 feedback unless it is entirely highway kms with basically no boost Im sceptical.
I reckon lots of parts could be sold to make alot more than $1500
it all depends how much you owe on it...
you dont want to end up being in debt for more than the asset you have on hand is worth, thats just silly...
No, i am being unfair in not mentioning im running map haltech e11v2 and im running a t04z so I dont get good boost till 3k and solid boost untill 4800 revs so its easy to not use alot :-)
A lot of my driving is main roads/highways but lots of hills... even in citys i still get under 12
I don't enjoy my $90 a week fuel bill. 15/16litres per 100km
yep, they are f**ked, having come from a magna wagon which does 11.9-12.3 in city, it was a rude shock..bit better with exhaust/cooler etc now..going to get it road tuned with nistune for sure...
cheers
darren
Hmmmm maybe you should have bought a second hand engine like everyone said last year.
BTW i got 515km out of my 33 without the light coming on :) Best i have done so far. Did a few off the clock runs as well (private property of course)
how would that affect my fuel usage?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
