I think you are a retard lilcrash.
You continue to be a fool and blame the turbo, yet, many of your symptoms to me could be many other things.
You had no clue what you were doing when you were rebuilding the engine.... Surging...
Could be anything,
like the timing gear..You could have a tooth out somewhere..
Or you could have a faulty AFM
or you could have a f**ked sensor...
Or you could have a f**ked CAS
Or while you're pulling your dick you could be accidently pumping the throttle...
Stop blaming the turbo that works on everyone elses car, and find the REAL problem. Stop being a lazy, whiney, spoiled little c0ck.
  • Replies 886
I have an idea.
Stao - send him a new turbo (no deposit or anything)
lilknob - you install new turbo, then send your old one back.
If you don't send the old one back, Stao gives me your postal address, I beat you sensless and post pics in this thread and have the title changed to "Thread for my brain problems"
Everyone's happy.
Honestly, if I were Stao I'd refund you the cost of the turbo purchase to stop these retarded posts.
Actually, how much do you want for the turbo?
I'll give you a stock RB25 turbo plus cash for your hypergear turbo.
Then I'll send it to Stao for a free replacement to a current stock item.
Then he can pull apart the "faulty" turbo and investigate if he had enabled the "Make car run like a bag of shit" setting on the compressor wheel when it was initially assembled.
Edited by TTT
Was going to agree but I think Stao has already done enough. Plus some of these post have gone well beyond defaming a business.
Kando seller is blocking customers if feedback isn't 100% yet Stao is still trying to help here
  • 1 month later...
Apart from the tune and usual underpoweredness it was sold in perfect running order. I couldn't deal with having a car with that I put so much money in being slower then my wife's accord. Now I've got a v8 Audi. Soon to be supercharged. :D
Edited by lilcrash
Hi all, first ever problem with my skyline in three years.
I have absolutely no power whatsoever when I try to start my car. Initially I thought it was a dead battery and had been jumping starting it until I have the chance to get a new battery, however the other night it happened again (believed it to be a dead battery) and when I went out in the morning it did not require a jump, started fine.
When it's dead there is no 'clickig' while trying to turn over, no warning lights etc whatsoever.
Could this be the starter motor/alternator?
Any ideas or help would be much appreciated.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
