i cant seem to find a thread listing places that are good so where does every one get their mild, stainless , alloy etc pipes from?
something like:
company name
contact details
address
what do they stock( pipe , sheet etc )
see if we can get the 1st post edited by a mod and group them by state
also where can i get a mild steel donut's?
Edited by Dan_J
https://www.sau.com.au/forums/topic/381400-fabrication-supplies/
great useful links guys :thumbsup:
ebay link is good, i only found their sister store kj trucks before hand
sent off a quote request for spareco and good to know their in VIC :)
keep the details coming, chat minimal and we may get a sticky to help the others out :cheers:
Depends how much of the raw material your looking to buy as to the best place to buy it.
For the DIY person you need to find a fabrication shop and buy their off cuts, then ask if they can buy in things like dounuts and longer tube lengths for you.
I do it for heaps of people who do minor stuff themselves.
The back of my guillotine is overflowing with decent sized off cuts that people drop in and pilfer scoring themselves a bargain.
The price you'd pay retail for a 1000x1000mm sheet of 3mm alloy I can buy 2 sheets of 2400x1200 so i let small sections go for bugger all.
There is also JNT performance in Wollongong. Steve is great to deal with and I know alot of fabricators who buy spun alloy products from him.
Also does dounuts, AN fittings and short sections of tube.
I pilfer the shops like what Risking mentioned. I go to a place called marindi fabrication, local stainless fabricator, is awesome to deal with and sometimes throws in pieces for next to nothing
It's the cheapest way when you only need a small section of sheet or tube etc.
I always get guys bringing in cardboard templates. They find some offcut ( which always has PVC covering so it's not scratched or anything) that is big enough for what they want and away they go.
Same for tube.
  • 1 year later...
  • 2 months later...
Can anyone recommend a shop in Melbourne to pick up some off cuts of stainless tube? Even mild steel. Also some plate/bar.. just some odds and ends really.
Cheers.
Check your local fab workshop or even a balustrading fabricator; they always have offcuts.
Offer them a sixpack of their favourite beverage; you'd be surprised.
I don't live in Melbourne yet (moving there soon) so don't have any idea about Fabrication shops down there really. I had some work done by Jake at JDI Fabrication in Bayswater, but he didn't seem to have much in the way of offcuts/scrap hanging around unfortunately.
  • 1 month later...
  • 4 weeks later...
I live in Wollongong so jnt is nice and close
as for other alloy stuff like sheets angles thick wall pipe ect i go to another local place called allyman they have piles of off cuts that you pay next to nothing for I always end up getting heaps more then I need
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
