Hi all,
After reading extensively in the Stagea suspension thread, i am still fretting about putting R33 suspension into the rear of my 1998 model S1 Stagea
Can anyone confirm they are actually running R33 suspension in thier stageas?
The reason i ask is because i have failing TIENS in the rear of mine at the moment, i cant even consider buying a new set, but i can find LOADS of second hand R33 suspension floating around.
does standard R33 suspension fit in too? or just coilovers, any clarification in the matter would bring me a great deal of peace of mind.
And i apologise for bringing up a topic that im sure most of you consider settled, i just have to be sure, rural areas means shipping everything in from interstate.
regards, Kyle.
https://www.sau.com.au/forums/topic/381526-r33-rear-coilovers-into-s1-stagea/
i have the AWD model, 1998 S1 AWD RB25DET
I read the suspension thread in detail, but a bunch of ppl say yes, and a bunch of ppl say no.. or recommend against it
I just need ANY rear S1 stagea suspension, stock would do me fine.
It is only ever me in the stagea so spring rates and ride height are not a big issue for me, im very rarely carrying any kind of load in the car, the only regular passenger i have is my workbag and it couldnt be over 2kg!
Hence why im asking if anyone has successfully installed GTST suspension into the rears without any issues, at wits end over here, as always :(
last resort: anyone ditching thier stock rear s1 stagea suspension by chance?
Pretty sure thats a no - no Skyline shocks in Stagea rears - fronts maybe but rears will be wrong for weight reasons let alone will it fit in the strut towers.
Hi,
Well Bob i run 34gtr shocks in mine,front & rear ,
i have modded rear shock as it was an Fork,
so they can be used at OWNERS RISK ,
if its a quick fix cool,
i had mine in for few months now & its ok .
im pretty sure standard stuff the skylines spring and upper mount are too big becuase stagea gear is narrowed for bigger cargo space. given that most coilovers are more compact than standard gear i would say they would physically bolt up (if you got the whole eyelet fork thing sorted)
Hi all,
regards, Kyle.
Would be good if you put your location in your profile. Have you looked into getting your Teins recond? Plenty of Stagea stuff for sale I have even posted shocks from here (Auckland, New Zealand ) to Aus so no need to be at your wits end - stay cool = there is a solution!
Is there a suspension shop within range? They may be able to swap out your shocks retaining the stock springs and tops and using common brands of shocks. Shocks only last about 80,000km or less under rough use so second hand stuff is no good anyway.
Sorry guys didnt think of this thread as i laid my hands on more tiens.
Im in "mid north coast, nsw - coffs harbour" the old set of tiens had 2 busted, might be able to be rebuilt i dont know.
i have some "street spec" tiens in there now, second hand but the ride is sensational. Im selling the Stagea now anyway.
anyone want an S1 for 7k? :)
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
