Hi all,
After reading extensively in the Stagea suspension thread, i am still fretting about putting R33 suspension into the rear of my 1998 model S1 Stagea
Can anyone confirm they are actually running R33 suspension in thier stageas?
The reason i ask is because i have failing TIENS in the rear of mine at the moment, i cant even consider buying a new set, but i can find LOADS of second hand R33 suspension floating around.
does standard R33 suspension fit in too? or just coilovers, any clarification in the matter would bring me a great deal of peace of mind.
And i apologise for bringing up a topic that im sure most of you consider settled, i just have to be sure, rural areas means shipping everything in from interstate.
regards, Kyle.
https://www.sau.com.au/forums/topic/381526-r33-rear-coilovers-into-s1-stagea/
i have the AWD model, 1998 S1 AWD RB25DET
I read the suspension thread in detail, but a bunch of ppl say yes, and a bunch of ppl say no.. or recommend against it
I just need ANY rear S1 stagea suspension, stock would do me fine.
It is only ever me in the stagea so spring rates and ride height are not a big issue for me, im very rarely carrying any kind of load in the car, the only regular passenger i have is my workbag and it couldnt be over 2kg!
Hence why im asking if anyone has successfully installed GTST suspension into the rears without any issues, at wits end over here, as always :(
last resort: anyone ditching thier stock rear s1 stagea suspension by chance?
Pretty sure thats a no - no Skyline shocks in Stagea rears - fronts maybe but rears will be wrong for weight reasons let alone will it fit in the strut towers.
Hi,
Well Bob i run 34gtr shocks in mine,front & rear ,
i have modded rear shock as it was an Fork,
so they can be used at OWNERS RISK ,
if its a quick fix cool,
i had mine in for few months now & its ok .
im pretty sure standard stuff the skylines spring and upper mount are too big becuase stagea gear is narrowed for bigger cargo space. given that most coilovers are more compact than standard gear i would say they would physically bolt up (if you got the whole eyelet fork thing sorted)
Hi all,
regards, Kyle.
Would be good if you put your location in your profile. Have you looked into getting your Teins recond? Plenty of Stagea stuff for sale I have even posted shocks from here (Auckland, New Zealand ) to Aus so no need to be at your wits end - stay cool = there is a solution!
Is there a suspension shop within range? They may be able to swap out your shocks retaining the stock springs and tops and using common brands of shocks. Shocks only last about 80,000km or less under rough use so second hand stuff is no good anyway.
Sorry guys didnt think of this thread as i laid my hands on more tiens.
Im in "mid north coast, nsw - coffs harbour" the old set of tiens had 2 busted, might be able to be rebuilt i dont know.
i have some "street spec" tiens in there now, second hand but the ride is sensational. Im selling the Stagea now anyway.
anyone want an S1 for 7k? :)
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
