  • Replies 105
Posted Images
That was a great idea Steve, I'll try to drag don along next time. Had a lot of fun and to finish close to Eric's GTR is a good result for the humble FC. Thanks Eric for the run, and rerun when i changed back to normal wheels. Battling is way better on rubber with tread :teehee:
Yeah Chris, I originally wasn't going to run my car at all. But, the slightest twist of the arm and well GD2ILA was itching to have a small strech of the legs.
Was good fun! I have some video that Matt was kind enough to film too so will put that up soon.
A little more awake now.
Thanks to officials for their time and efforts. Thanks to Reece for jumping in the car to give to me pointers, I may have seemed very confused but your tips through the day made a big difference. Slower is faster but it's hard to resist the temptation to make the tyres scream. cheers.gif
Did anyone get a shots or a video of my Stag going around? Would love to see it doing it's thing, hopeful of the one hand break turn that was right.( out of many attempts ) thanks.gif
For a first timer everybody made me very welcome. Anybody sitting on the sideline worrying about being a novice or breaking your car - don't be, it's all at your own pace. As for breaking your car - refer back to previous comment re slower/faster. thumbsup.gif
I now just need to sort a new clutch before the next one so I can do those 6k launches . nyaanyaa.gif
and yes this thread needs more photos and videos.
You did great! And I think another point to make is that you drove home on the tyres you came with... so anyone thinking it's an expensive day out cos you need 11ty sets of tyres (as previous pictures would have you believe :P ), it doesn't have to be!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
