If you are a Vic member, you can enter for FREE! Or even turn up and be in a chance to get something Free!
http://www.skylinesaustralia.com/forums/topic/378514-sau-vic-show-n-shine/
We will have some Vic merchandise and member sign up form on the day.
Everyone and anyone welcome can come down on the day for a chat and look at some mad cars.
Sunday, December 4th
10:30AM - 3PM
https://www.sau.com.au/forums/topic/383905-2011-show-n-shine-car-show/
  • Replies 94
That is the time the cars must be there, if you are just coming down for a chat you can come later and leave earlier.
This is in the general section I so though more non members would be reading it, so not entering cars closedeyes.gif
If you plan on taking your car, and why not there are a bunch or prizes. Please read the thread linked in the first post, it contains all the information you will need.
If you turn up late with your car, sorry but the council have everything locked down so we cannot get you in.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
