^ haha will post something up soon dude,
so bit the bullet and upgraded my coilovers, first time ive ever had brand new coil overs, should be good
ended up getting CS2s with 9kg fronts 7kg rear. pretty easy fit, just needed to redrill the rear strut tower to two bolt. cheers to brae for his wisdom and help!
fronts had been leaking for ages and where only tein HAs
^ one of the main reasons i go these was because of the extra castor adjustment u can get, still need more thou so will look into modifying these in the future
  • 1 month later...
^ haha no worries, yea i miss the fj :( i have ideas of going back to one, you never know.....
Brae was nice enough to mod my LCAs 25mm, so 50mm total more track, should be good, fitting up new balljoints and bushs today
thanks mate
also did the hit and run waki day couple weeks ago, second time at waki, pretty cool lil track
this is what ive been playing around with recently, basically wanted to get rid of the castor bushs and go a rose joint, theres a few kits ive seen but i still think they have to much going on, wanted to keep it simple, so to follow the trend of silvia front end, ive gone to modified s14 castor arms, boxed and modded dr30 castor brakets to suit
boxed and brace welded in
brae worked his majic and extended these by 75mm, will look into making up a one peice section next year when im sure the lenghts are spot on
dummy fit in car
hole saw out original castor bush mounts re drill to suit rose joint,
i wanted the rose joint to bolt up here as its the strongest part of the castor braket
boxed up
also got these offset rack mounts, hopefully theyl work...
love this build, its DR30 and drift what more could you want
now with the new castor rod set up you'll be setting up the camber tops to be camber adjustable only i figure
also give us an update on how the powered by max offset rack mount bushes go and if it reduces bind for the 6mm of location change
  • 3 weeks later...
figured out the lenghts needed, Brae worked his majic again, and made up a one piece section, since we used GKtech castor arms and then modified them, we thought it would be good to appropiately name them "GF Tech" ;)
cheers again brae for all your help!
fitted up a s14 rack, you can kind off make out the difference in thickness, on the left hand side tube, fitted up pretty easy, just needed to use the s14 low pressure fitting, and bend high pressure fitting abit to suit, im hoping because the s14 rack doesnt have the speed sensor in it, maybe my steering will be better...
ive also fitted up the psm rack mounts, so far so good
also needed these, with the extended lcas, tie rods ran out off thread ... these are said to give u 25mm extra tie rod length and 19mm more rack travel..
drifting next weekend, hopefully car goes well
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
