Hey Guys,
I pulled my front bar off yesterday to find that half my fins on my intercooler are bent over hard and this is most likely contributing or the source of my weird overheatign problems atm. So im going to get a new intercooler.
There are heaps of coolers for the 32/33 gtr but not many other than the 2k HKS kits for the 34.
Im looking at the cooling pro ones for the 32/33 GTR. I have HKS GTSS turbos so im not after massive power.
Question is: How hard is it to mount the sensor from the std 34 GTR cooler into those and is it even nessecary.
Next: Are there any physical differences in the mounting points etc etc.
Or if someone can suggest a replacement cooler for under 1k Im happy to listen
https://www.sau.com.au/forums/topic/384156-r34-gtr-intercooler-question/
use a comb or a flat blade screw driver and straighten the fins, Just thinking of it there is a tool you can buy for it, I think most refrigerator repair shops sell them
annnndddd found one
http://www.awesome-gti.co.uk/product.php?xProd=36561
Are you talking about the intake temperature sensor?
If so, not necessary but it's not hard to do either. Just tap the holes for the screws or even get self tapping ones. Drill out the hole you need for the sensor and presto!
My sensor is hanging in the air at the moment as my cooler is not meant for the v-spec models. I'm waiting until I buy the hard piping kit then I will mount the sensor the same time the bar and cooler is off.
Greddy sell intercoolers with the sensor tappings in place as I had one on my old R33 GTR. I just had to use their blanking plate.
can you define the "weird overheating problems"
i would be totally gobsmacked if bent fins caused your weird overheating problems
ie; it doesnt make sense
bent fins could marginally affect inlet/outlet air temp but your wording sounds like water temp / radiator problems
are you mixing the two up?
Ok then.
I have a nismo radiator and thermostat.
The car used to run at 72-75.
It will now go to 75 then hop upto 77 then jump upto 85. If you stop it climbs up into the 90s. Once you start moving it gets back down to 80 then ever so slowly back to 75-77.
I have had it looked at by two workshops and everything seems fine to them. The cutch fan seems to throw a fair bit of air upwards but if you put your hand behind it, just doesnt feel as if its dragging much air through the radiator. Ine if the workshops put the dyno fan in front of the car and said it cooled back down then. So seems like an airflow problem. The car has been bled up a few times to elliminate air pockets, I have changed the coolant.
air lock in the coolant passages?
I too am with Paul now, if it is idling and getting hot than it isn't the intercooler, if you were cruising down the highway and it was doing it than yes, the cooler could be clocking air
Maybe the warmer weather has something to do with it? The fact that you are getting rising temps when sitting at lights is not an indication that the problem is the bent fins as no air will be passing through the radiator at that time. Your clutch fan is spinning and pushing air through the radiator(or sucking, I don't know) but the fact that you drive and it cools down to 75 is an indication that air is coming through. From 90c to 75c when you start moving.... its not luck, its functioning.
Edited by SargeRX8
Yeh im stuck on what to do. As I said the car has been bled a few times to get around an air lock.
I put my hand in near the front side of the radiator before and I could feel it sucking air through. I have had the car for about 6 months and I live in QLD so yes getting the hot weather, but still doesnt make sense for it to rise that much. Before the turbos went on it had no problem with the temps.
Oil temp is between 84-91 so that seems normal.
One of my turbo water pipes has a bit of a kink in it, but not enough to stop coolant flow.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
