Hey Guys,
I pulled my front bar off yesterday to find that half my fins on my intercooler are bent over hard and this is most likely contributing or the source of my weird overheatign problems atm. So im going to get a new intercooler.
There are heaps of coolers for the 32/33 gtr but not many other than the 2k HKS kits for the 34.
Im looking at the cooling pro ones for the 32/33 GTR. I have HKS GTSS turbos so im not after massive power.
Question is: How hard is it to mount the sensor from the std 34 GTR cooler into those and is it even nessecary.
Next: Are there any physical differences in the mounting points etc etc.
Or if someone can suggest a replacement cooler for under 1k Im happy to listen
https://www.sau.com.au/forums/topic/384156-r34-gtr-intercooler-question/
use a comb or a flat blade screw driver and straighten the fins, Just thinking of it there is a tool you can buy for it, I think most refrigerator repair shops sell them
annnndddd found one
http://www.awesome-gti.co.uk/product.php?xProd=36561
Are you talking about the intake temperature sensor?
If so, not necessary but it's not hard to do either. Just tap the holes for the screws or even get self tapping ones. Drill out the hole you need for the sensor and presto!
My sensor is hanging in the air at the moment as my cooler is not meant for the v-spec models. I'm waiting until I buy the hard piping kit then I will mount the sensor the same time the bar and cooler is off.
Greddy sell intercoolers with the sensor tappings in place as I had one on my old R33 GTR. I just had to use their blanking plate.
can you define the "weird overheating problems"
i would be totally gobsmacked if bent fins caused your weird overheating problems
ie; it doesnt make sense
bent fins could marginally affect inlet/outlet air temp but your wording sounds like water temp / radiator problems
are you mixing the two up?
Ok then.
I have a nismo radiator and thermostat.
The car used to run at 72-75.
It will now go to 75 then hop upto 77 then jump upto 85. If you stop it climbs up into the 90s. Once you start moving it gets back down to 80 then ever so slowly back to 75-77.
I have had it looked at by two workshops and everything seems fine to them. The cutch fan seems to throw a fair bit of air upwards but if you put your hand behind it, just doesnt feel as if its dragging much air through the radiator. Ine if the workshops put the dyno fan in front of the car and said it cooled back down then. So seems like an airflow problem. The car has been bled up a few times to elliminate air pockets, I have changed the coolant.
air lock in the coolant passages?
I too am with Paul now, if it is idling and getting hot than it isn't the intercooler, if you were cruising down the highway and it was doing it than yes, the cooler could be clocking air
Maybe the warmer weather has something to do with it? The fact that you are getting rising temps when sitting at lights is not an indication that the problem is the bent fins as no air will be passing through the radiator at that time. Your clutch fan is spinning and pushing air through the radiator(or sucking, I don't know) but the fact that you drive and it cools down to 75 is an indication that air is coming through. From 90c to 75c when you start moving.... its not luck, its functioning.
Edited by SargeRX8
Yeh im stuck on what to do. As I said the car has been bled a few times to get around an air lock.
I put my hand in near the front side of the radiator before and I could feel it sucking air through. I have had the car for about 6 months and I live in QLD so yes getting the hot weather, but still doesnt make sense for it to rise that much. Before the turbos went on it had no problem with the temps.
Oil temp is between 84-91 so that seems normal.
One of my turbo water pipes has a bit of a kink in it, but not enough to stop coolant flow.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
