The stepped nose is there to meet crash regulations
I cant remember the exact specs but all the teams noses raised at to shallow an angle to meet crash standards. Because the teams had already designed the cars, the stepped nose was the answer. Mclaren and Marussia were exempt because of the way there nose designs were, or they met the regs with a front end re-design
This was 9 months ago I dont remember properly lol
yep, they changed the rules because they feared the high noses might take a drivers head off in a crash.
  • Replies 5.5k
Posted Images
All cars comply, including McLaren and Marussia. The rule change was to limit the height of the nose so that in an accident the nose cones were not going to go over the sidepod and hit drivers. Most teams lowered the noses and when they reached the area of nose where the height changed they simply put a step in it. McLaren, Marussia and HRT decided to use a countour others a step. But all cars comply
tricky little aero foils I'm noticing for the first time there
it's the little tweaks that matter :happy:
Really?
They ran them in belgium I'm pretty sure. While watching the stream for practice they had a thing about them
Nup.
Red Bull Racing's Mark Webber has been cleared by the stewards after it was alleged he impeded Timo Glock during the opening qualifying session for Sunday's Singapore Grand Prix, although he still picked up a reprimand for a separate incident.
The Aussie was exiting the pits in Q1 when it was deemed he might have held up Glock, something that could have landed the Aussie with a five-place grid penalty. However, after considering the matter, the stewards ruled that there was no case to answer.
The statement from the stewards read: “On the lap of the alleged impeding Timo Glock braked at T1 earlier than his previous best lap in that session. By the apex he was 0.105 seconds slower. At the apex of T3 where the alleged impeding occurred (where Webber was in front of Glock) Glock was 0.090 seconds slower than his previous best. Glock overtook Webber at the exit to T3 on the racing line, braking into T5 earlier than his previous best lap and was now 0.198 seconds slower. At the end of Sector 1 (i.e. after T6) Glock's delta time over his previous best was 0.380 seconds slower. Accordingly from the telemetry it is concluded there was no time lost whilst behind Webber - the time loss was before and after the alleged impeding. Therefore no impeding occurred.”
The stewards also added that 'Webber had no vision of Glock on exiting the pit lane', and 'a review of the GPS system showed Red Bull Racing did not have information that would have enabled them to warn Webber of Glock's approach'.
Meanwhile, Webber did get a reprimand, however, for twice leaving the track on his in-lap at the end of Q3 - a breach of Article 20.2 of the FIA Formula One Sporting Regulations.
“The driver could offer no justifiable reason for deliberately leaving the track,” the stewards added.
» 4 comment(s) on this Story » Post your comments on this Story
http://www.crash.net/f1/news/184281/1/webber_escapes_grid_penalty_handed_reprimand.html
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
