Wow. What an incredible read!
Now I'm thinking that my choice of -5s wasn't such a great idea.
Those Gtx's work wonders but I presume better match stokers rather than 2.6
Also nissan4life sensational driving.
Was that at QR?
Shame you sold the car would have loved to see it.
The boost got up to 33psi with the 478kw, but at the track that day I was winding it down to 27ish.
Don't worry about the -5's purchase, that's what i have used to put the GTX 2863 cores into. If you are 2.6L the GTX2860's will be a better fit.
Yeah mate that was at QR, cheers for the kind words on my driving, but I still got ways to go yet. I have been getting some practice driving an SR3 Radical of Paul Stokells, so that has been good.
Thanks Simon, think I will have a look at the GTX2860'S
Yeah, I know Paul Stokell racing gives great opportunities for those are looking for it, good stuff.
I will be venturing up QR again very, very soon ;)
I would like to know how the front compressor housing works for RB26 :
Do we have to pick a RB skyline front housing, the chra gtx2860 and the -5 rear housing and it all bolt on ?
or does the Front housing is machined to the CHRA and bought like that ? Because I can't seems to find any shop selling gtx2860r with RB style ( only see it advertised on atp for the gtx2863)
Yes, but compressor housing needs to be machined. I believe -5 comp housings should be used
Although I cannot confirm this, I don't think it would be long before Garrett Honeywell puts this on their marketing table and hopefully sells it RB style.
Not that hard for them to do really and the extra $$$ they will get for it as well
Okay, I got all excited, just to realise that theres like 600$ of machining involved. A little too rich for my blood then :S
It's a drop in the ocean considering it's one of the main parts directly influencing power delivery.
  • Like 1
I will think about it, but still.. chra = 1200$ shipped x2. worn-out -5 ( maybe 300-400$ for both) + 2x actuator 80$ + 600 machining = 3500$ .might as well consider the efr8374 ( oops I dont want to open a can of worn! sorry)
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
