After much thinking and discussion with my mechanic, a single turbo is a no-no... ( sure it's the way to go.. but its also about 7.5k once everything is done lol)
So I came back with my initial idea to get a GTX upgrade. And I would like your input, especially with the folk who had it done.
Finding a turbo tech in my area who is willing to machine/work a gt2860 compressor housing to the gtx28 cartridge seems impossible.. I would need to ship it, pay more , waiting time.. All in all, seems like I can't find anything for less than 200-400$ ( rough estimation).
So, I'm thinking how much of a hassle it is to redo some piping to make the gtx compressor housing with gt2860 exhaust housing bolt on a rb26 ??
Thanks for your input!
And if I may, do we agree by saying the gtx2860 should yeild spool similar to gt-ss and gtx2863 spool like -5s ?
I can't see how the 60 mm gtx's will spool up like a -9. That's a huge ask for what is essentially a 400 hp turbo.
New wheel design along with ligther material and anti-surge cover could be a factor in the spool time. Food for though... I'm really not a turbo expert and trying to learn as much as I can recently.
like said before. running past 25-28 psi can be playing with fires if no good fuel. I'm running 94 octane + WMI so I don't really expect to run past 28psi.
Don't bother with GTX then.
  • Like 1
I spoke to the guy that tunes my car and he said to go the 63's. Now considering the -5's are a 360 HP turbo, 60's are a 400 HP turbo and the 63's are a 430 HP turbo, I'm not sure if I need the 63's. The 60's should (on my engine seeing that the -5's have already done 472 rwkw) do 500 with a much better curve to match (as you have not given away anything at any point), couple that with a 250 degree at 11 ish mm lift and it would be silly. What I am really curious about is that throttle response/lag between gears. It doesn't exist!
This is what I was hoping with gtx2860.. Not really after extra whp. the extra 40hp is just a bonus for me. I was hoping the gtx didn't need to be pushed to 30psi to get this ''benefit''. Had a read on the zilvia forum today and it seems like the gtx does offer a better throttle response than the older gt28.
Edited by cobrAA
New wheel design along with ligther material and NOT THE anti-surge cover could be a factor in the spool time. Food for though... I'm really not a turbo expert and trying to learn as much as I can recently.
Just to prevent mis-information.
FWIW, I recently upgraded my twin GT2860RS turbos to twin GTX2863s. I'm running Tial 0.86 AR turbine housings, externally gated with full recirculation, and I'm on a full house stroked 2JZ-GTE motor with literally all the bells and whistles.
I made ~10% more power at ~10% less boost, and the biggest difference to me wasn't just the top end, which was epic - it was part throttle and low boost. For a street car - literally daily driven, on BP Ultimate fuel and WMI - this was an ideal upgrade, and most unexpected in many ways.
The combination was a much happier one than the one it replaced, which was by no means bad. Revved easier, took more ignition timing, was less noisy - full of win.
Obviously it is difficult, if not impossible, to compare my setup directly to anyone else's on this board, but I still think that it is indicative as a data point.
  • Like 1
So after looking into putting the 63mm wheels into my -5's i sent am email to GCG to see what their opinion on this combo would be like, and here is their response for those interested.
"We have had customer feedback in regards to this particular set up and it isn't positive, apparently they surge severely if fitted with with standard style housings on both ends unfortunately. Garrett do not do any GTX upgrades for the RB26 set up so we are currently working on a solution to this, pretty soon we will be bringing out our own range of custom stainless steel housings in 0.86a/r to replace the restrictive Garrett 0.64a/r housings (wot work with the GTX28R range), but this won't be ready until later this year.
The other thing as well, the surge slotted comp housings would have to be utilized with this set up so a custom intake would be required."
I wouldn't be so quick to take their word as final, I have had huge success with my -5 with GTX 2863 cores in there with machined font housings and have experienced no surge issues at all.
Yeah i see you have had great results with your set up with a 2.8L and head work. Maybe surge would be an issue on a 2.6 and small cams.
Iam seriously liking the idea of tial .86 V band housings and external gates just don't think there would be enough room not to mention getting custom manifolds made up hmmm..
Around the 500kw mark. Yeah your right is a ton of extra work, just something different that hasn't been done before that i am aware of. Nothing is set in stone just kicking a few ideas around.
Easies and cheapest option would be just to put the 63 cores into my 2530's and get the 2.8L built with full head work.
  • Like 1
GTSS RB26 edition was a special designed to replace the standard RB26 ones so they are customised engine/car specific units .
Part of what makes them work is the smaller than usual trim NS111 turbines , 62 rather than 76 trim . Once you start talking GTX2860 you get the larger 76 trim turbine standard so pointless comparing them to any GTX28 turbo . It's probably safe to say that the GTX2860R is like an updated GT2860R 63T (2530) which aren't exactly small for a sane RB26 . The big trim turbines that may give some initial lag I'd say help get around the surge issues so whilst not a perfect solution a workable one .
I think that if Garrett/HKS were to do GTSSs again they would use a more modern compressor in possibly a smaller diameter . RB26s are getting long in the tooth now and there probably isn't a big enough market to justify Garrett doing anything new for them .
A .
Of course a pair of GTSS aren't going to flow 500kw very easily either.
I was in the passenger seat while Trent tuned Dez's GTX upgraded -5's and while they were right on the edge of wot surge it was quite hard to pick it. I have heard much worse surge before. Of course his engine had cams and a fair bit of work, and every engine behaves a little differently.
GCG were right to be worried, but that shouldn't put you off. They have little idea when it comes to turbo's running in the real world, they are just resellers.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
