just pulled the engine off the stand and encountered my forst problem with the spool crankshaft. The flywheel bolts need to have a washer on them or shortened due to the factory bolts bottoming out. On to the lathe they go then!
if i found a double jointed female id be pimpin ma DJ hoe fo sho!
No but seriously, im 6foot4, and resemble some large primate species, gorilla like.....i can only just fit my hands in the bloody cavity the bastard goes!
yeah, i got it. ended up removing the alternator and oil filter and going through the front of the engine bay. I despise the starter in these cars, i almost bled to death lol. Its all starting to come together now, just waiting on some ned alt, ac and ps belts to arrive, a new supersnail to arrive and then its off to the fab shop to get a PS resivoir relocated and hotside piping made up along with a dump and exhaust! Pics tonight :)
Well, engine harness is on, cold side is 95% complete, just waiting on a new fuel filter and some fuel line, then i can bang that in, put the cooler hose and radiator hoses on and im on to the injectors! Was considering going a set of "Adaptors to go from the ID's to the standard plugs, but im instead going to remove the old plug and hard wire in a new plug as it looks neater and there is a little extra wire there if in the future i decide to change my mind again.
Id like to give a big shout out to paul, aka PIGGAZ for his help, and also a shout out to the greater SAU community for thier knowledge of all things arr bee!
Now, some boring, but progressive pictures!
On the way in, by yourself, this method makes it an absolute fcuking mission!
In the hole!
And as it sits at the moment, waiting for some precision goodness so i can start routing lines and making a dump!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
