  • Replies 40
Yep, that was mine.
Hmm, 750 bucks currently for a leather interior, popup screen, reversing camera and Nismo exhaust which are all in good condition.
Turbo, intake, dump may be okay, but I don't know.
Steering looks fine!!
Oh, and that headlight was fine Alex :P The other one, well that was in a million bits... instantly. Can't believe how readily they disintegrate!
Scott, and what radiator cap to you have Mr. Mishimoto?
http://www.skylinesa..._1#entry5148591
Any Nissan/Infinity dealer in the US, I went through West Covina Nissan for mine, but they are not so cooperative since Tony left.
Might even be some on Ebay Motors.
Should be a bit cheaper now though, I believe my mate got his recently for around the $100 but really needs to make up a couple of brackets.
How much factory bodywork did you need to cut? Any pics?
looks a lot neater with that cover.
Cheers
Yep, looks waaay nicer with one.
If you look at yours, you will see that there is an extra 10-15mm(?) of metal above the square rubber grommets for your hoses.
Cut that in line with the top of the grommets and run a brush with some rust prohibitive paint, then all you need to do is make up a small bracket for the top right section of the cover and cut a little in that area to fit :)
Surely they have some stupid hidden reserve for like 6k?
Yep, I was told they had $6k on it.
You can't cut the plastic cover?
I'm somewhat interested, but I can't find the run through from last time you did the group buy - am I just not searching properly? It's not on here or the 'somewhat awesome' forum as far as I can tell?
You won't find one.
GB didn't go ahead and it was only after I installed mine that I thought of offering the GB.
I think you can cut the plastic cover, but I couldn't see doing so would end up with a satisfactory finish so I cut the top strip of metal instead.
No need to worry Ryan, it is not a big job.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
