Hi guys, just a quick question. I plan to build a project car soon and having a bit of trouble finding a turbo to suit, can this turbo be modified so that the centre section (oil feed and return inlet/outlets) are on the opposite side as shown, I need to have the oil feed to be on the same side as the flange. Is it just a matter of unbolting and turning it around then rebolting it up. I know its only a cheap and nasty turbo but it would work for a starting point. I asked the seller and he doesnt seem to have much of an idea.
http://www.ebay.com....E:X:RTQ:AU:1123
Edited by chris_82
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/
That turbo will probably go like a bag of shit and last one oil change.
You will spend more money making parts to fit that turbo, like dumps cooler pipes and lines then you will buying the turbo ETC.
Buy something decent from the get go, Kando Dynamics are cheap and reliable:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-RB20DET-RB25DET-2-4-Cover-8cm-T3-V-Band-TD06SL2-18G-/290635791753?pt=AU_Car_Parts_Accessories&hash=item43ab3e3d89
That would be a similar amount of effort to install but would be worth using if you are funds limited. That or a hypergear highflow would suit you better.
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147578
Like i said but few of u actually took note of what i was saying, I know its a crap turbo. But that wasnt what i was asking, i was asking if they can be pulled apart and altered. so thanks sarge thats all i needed to know.
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147658
You wouldn't need to know that if you weren't going to buy one.
You do realize these turbos usually last a run or two on the dyno and then blow?
Make sure you post back your results so that we can say that we told you so.
Of you do decide to smarten up, buy a kando.
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147665
OR hes the annoying weasel coming back like "nah nah, ive been floggin it for 6 months, you're all f**ked!"
To which we sit and play the waiting game :P
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147669
lol u guys burr up easy. or what about this one, comes with a 16psi actuator so id have to swap it out for a 7psi one.
http://www.ebay.com....#ht_6487wt_1396
And yes i will post pics when its all completed
Edited by chris_82
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147706
Oh that ones different. It not only explodes but it has a new technology from china that infiltrates your engine ;)
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147719
Those ebay turbos are great for bush bashers :D. I know a guy who threw one on a old MX6 he had in the paddock, bought turbo manifold, turbo, cooler etc off ebay and got a FPR and a 12:1 vortech FMU....lasted ages with that haha
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147771
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
