Hi all , recently I bought a 9RS turbo for the Lancer and I got the chance to look at a wide range of Mitsubishi turbines and compressors many of which were aftermarket .
It was quite interesting to compare OE cast wheels like 15GK2s and 16/18/20G6s and even a few CNCd HTA wheels as well . I would like to have seen a GTX wheel to compare to the HTAs because some of the differences between the cast Mitsy wheels and HTAs look to be the hubs section . The billet wheels have less hub and more blade which may be part of the reason why some of these billet compressor wheels of similar diametres can have greater capacity than earlier cast ones .
I remember reading that part of the compromise with cast compressor wheels is that they have to be easily and reliably removed from tkeir moulds and this could have performance limitations . It was pointed out to me that even GT compressors like the 71/76.2/82mm ones are sort of fat in the hub and this could be part of whats driving Garrett to make their GTX billet CNCd wheels .
I do know that there are other differences like blade counts and that port shrouded compressor housings are more common on these units .
Possibly one of the selling points of the GTX turbos is that they can run port shrouded comp housings and not get the jet turbine sounds which is better IMO . Also wheel development should be faster and cheaper when your residant computer geek can punch the numbers to get the machining center to carve out whatever you like . It would be a similar deal with housing profiles and when you already own extensive test rig equipment its all good .
If only the turbines were as easy , cheers A .
https://www.sau.com.au/forums/topic/386243-compressor-wheel-designs-changing/
looking at the GTX compressor wheel on mine recently, it looks very different to the old garrett that came off, looks soft like aluminium and the very curvy. looks alot more aggressive not that ive seen alot of them..
Not sure if you frequent the Hypergear thread Disco but the whole purpose of his CNC billet wheel adventure was to test out the 'more blade less hub' concept.
Seemed to work for him too, there are losses in response evidently yet if manufacturers could hunt for a happy medium we could see great things.
I think one thing that needs mention at the moment is the push to big pressure ratio capable compressors.. There seems to be another tradeoff there which I think could be hindering us 'cheap' folk with older cars and smaller budgets. I would like to see manufacturers go back to low pressure high volume designs for us hobo's.
Otherwise MHI still has our back's.
Yeh, I am getting a HTA wheel on my TD06. Slightly bigger wheel but as you say the hub section is a lot narrower on the machined jobbie so more space for blades, hence the large increase in flow for little change in overall physical dimensions. Will know by end of Jan how it actually works in the field :)
Not really bigger the better, the thinner the hub the more inconsistency in flow. Also the shape of hub, blades, wheel dimensions and etc all makes differences in response, and power.
They needs to be very carefully trailed refer to capacity and flow of each engine for the best configuration within the target HP range. We've been making and trailing customized billet wheels for the whole year, and there are only 3 designs made "positive" differences, rest of 10+ went back wards compare to traditional cast wheels, how ever those didn't work provided directions in terms of effects on every little changes made, some of them are considered perfect for SR20dets are not so good for rb25det.
No one would be spending $$$$ in programming, tooling and testing without prove of concepts and directions.
The only way to reach an goal on an engine is to prove the concept behind it on that engine. This also apply to turbine wheel, and housings profiles.
What ever "moved forward" on papers only count when it "moved forward" in real life.
Magic software does not exist.
Im sure Garrett engeneers would be using flow analisis programs for pre-testing not just cutting new wheels and trialing them without some idea of what would work.
If you're thinking "flow analysis" meaning CFD, then I'd be reasonably certain that there's no computational fluid flow modelling software that would do a good job of it. Fluent/CFX/Ansys is pretty good code, representative of the best CFD capability available, and even for relatively simple geometries and flow situations it requires a huge amount of expertise and cross-validation work to generate modelling output that is trustworthy. (Anyone who trusts CFD output without cross-validation does not understand what CFD can and can't do.)
CFD has a hard time getting the simple things right, like a backward facing step in a duct (ie a step change increase in pipe diameter) in steady state flow. If you carefully tune the turbulence models used so that they will handle a backward step, then they completely fail at swirling flows. A compressor wheel is a horribly complicated geometry to model, and it is not stready state, it is time varying, and it is full of swirling components, and it takes the gas velocity and dynamic pressures way up past the sonic limit. All of these things are hell on CFD codes.
You could so some limited modelling, but there is no way that you could satisfactorily CFD model a compressor wheel and get output that you would trust. I would say that these things would still be designed by experience, black art and testwork as much as any other way.
Thats right. Its not just software. You need advanced knowledge of fluid mechanics and turbine design to validate any model.
And then you need to be a boffin in a cardigan to understand the fluids to the point that people are chasing effeciency.
I did a CFD elective years ago at Unni. Hated it. FEA was much better and made more sense to me
Bring on F1 turbos and some rapid developments in the tur ine and compressor design, materials and manufacture
It is cheaper to just trial and error model a compressor wheel, I would go to the point of saying I don't think it is even possible to correctly model a turbine wheel in flow dynamics software.
They would use existing models generated from trial and error data to "design" new wheels.
Edited by Rolls
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
