  • Replies 231
Tyres and suspension are your big ones in a Gts t
Yes it's the key for the low 60' time.
I know a stock GTST with a 100 shot of NOS and drag radicals did an 11.4 IIRC, which is quite stupendous.
never happen on street tyres
drag radials as a minimum and you would be looking at 550+bhp at the crank to get you a high 10 at around 130mph after lots of practice
Auto or manual?
Manual.
So that is ~350 rwkw then?
What is a 350 rwkw car gonna do on street tyres then? I don't just mean $100 a corner china spec but semi-slicks if necessary.
What tyres?
And can the person drive?
Two most important things over power IMO. If you can't drive you'll need a LOT of compensation (power & auto probably the easiest)
I'm talking potential really. Like how a $10,000 piano can sound better than a Bontempi keyboard but only if the person can play it properly.
as others have alluded too it will take more than just power.
Circuit semi's are rubbish on a drag strip, will need the correct tyre's for the job
plus you could have 350rwkws but if the car is laggy as hell then it wont run a 10
I know of a 1000hp R33 GTR that barely runs 12's because it is so laggy.
Have you dont any drag racing at all before?
I have done a fair bit and I still suck balls at getting a manual car off the line well
What suspension do you have? sub frame mods?
Well it is not my car per se. I am talking a GTST in an abstract or hypothetical sense.
But thanks for asking about my car anyway. :thumbsup:
Suspension wise I have HKS coilovers, whiteline sway bars, just the main subframe bushings are poly, camber arms. Have a Cusco mech LSD as well.:cheers:
well if it is hypothetical
4 link rear end, RB34, Auto, 5000+rpm stall and n2o to get it on boost on the start line
Seems a bit pessimistic when you consider a stock one has done an 11.4 with a 10lb bottle of laughing gas.
dropping 7/10ths at that level is a lot
eg twin turbo soarers are running 11.6's with just a front mount, boost and ECU
10's is a whole other ball game
obviously you dont need half of that stuff I listed
you don't need any of that stuff.., unless you want to run 8's haha
cheers
darren
Edited by jet_r31
There was a R33 GTSt for sale a while ago, had a powerglide, high stall, GT35R etc and did 10.9 or something. Apparently only 288rwkw too.
Yeh but if it was manual it would make at least another 35-40rwkw, but dyno figures don't mean shit, they are all over the place at the best of times.
cheers
darren
I did a 12.3 in a full weight 25/30 GTST 5 spd, 350 killerwasps, GTR diff, 245/45 17 Dunlop Direzzas, Bilsteins and kings, I had about 30 goes at trying to better it at the SAUNSW drag day, terminal speed was 123 mph, 60 foot was 2.? seconds which was crap but the tyres just kept bagging up, if you got some good drag radials and stock shockers you will most likely get a better 60 ft time, BUT, in all honesty, you may be dreaming.
10.99 is along way away from 12.3, Im hoping for 11.9 next time but I will be using drag radials.
:cheers:
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
