  • Replies 742
rumours of an R32 being built for Pro class with cosworth backing and VR38DETT engine running R32 drivetrain
goal of top 3 pro class finish
now that would be interesting to see
do you know which workshop or just whispers
Hopefully you get more testing in this year Mark :thumbsup:
as for the cyber GTR here is a tease from them
working in the pits along side tarzan yamada and takizawa san last august was a great experience. very humble but experienced and knowledgeable team.
I am sure they will put together a very fast R35 time attack weopon for 2013
From the Superlap facebook page. Definitely seems to hint they're coming
https://www.facebook.com/photo.php?fbid=2769690404204&set=a.1350482684898.2050138.1316293917&type=3&theater
That is one hell of a sexy man standing in the background of that pic
http://www.ebay.com.au/itm/Nissan-Skyline-V8-4WD-ADVAN-Race-car-SUPER-LAP-/270887993160?pt=AU_Cars&hash=item3f122ebf48
^this one?
it has a VH41 but. :unsure:
Planning on entering JET200
- fix oil surge with custom sump and accumulator
- fit 295s rear and 265 or 295 front
- finally put some front aero on it
- boost per gear mapping
dog box and other stuff too expensive and have to wait.
Aim for 1:37 bracket. WInning open is WAY too far off these days
Will have Motive stand there and maybe we can make a DVD again this year
When's 2011 DVD coming out??
Seems like oil surge was a common problem last yr as everybody upped the aero and grip
We were paid to make it in 2010
Weren't contracted in 2011 and originally told couldn't make our own one, then a month after event were told we could.
Have enough content to make a DVD but no budget.
If we know in advance we can pre sell air time and copies and afford to make a 2012 one.
Will have a fair bit of content in next Motive DVD though
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
