This is a good thread for potential GTR owners....buy a GTR, then budget the cost of purchase for onging maintenace/upgrades/surprises. Still beats playing golf for kicks though!
Hope everything is progressing well.....very keen on updates!
Edited by nick_7g
  • 4 weeks later...
  • 1 month later...
What dumps are you running??
standard dumps
Standard Dumps???
I Cant believe you went to the trouble of changing out turbos, fabricating custom front pipes & exhuast and then left the biggest restricting factor in the system on there...
Not sure if anyone else has suggested but if they are the cast ones...they are only good as paper weights, get a set of the stainless R34 GTR Dumps at a minimum...
Watching this space!!!
Edited by krayzie32
  • 3 weeks later...
the car is now back with the tuner
with the following additions:
- OS Giken 3 Gear Set Box
- Koyo radiator
- New water pump
- Gates belt
- New seals
have also given tuner the following:
- ARP studs
- Tomei head gasket
- Tomei cam gears
head is being pulled apart to have springs/valves adjusted.
Hopefully have some good news this time next week!
Edited by usmair
I made 340rwkw @ 18psi through stock R33 GTR dumps without a problem at all.
Put on Tomei ones when i put on -5s (compared to other -5 setups using stock dumps, same spec built engines/dyno), the only difference... The exhaust note sounded different. So probably not the best $600 I'd ever spent.
thanks for yuor honesty! I actually sold my tomei dump and manifold before even using them, used R34 one and r34 ported manifold instead.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
