Bit of a noob question but it needs to be asked.
Just realized when checking my tire pressure that I have two different sets of tires on my car, Playz PZ-1s on the left, and Playz PZ-X on the right...
Now I've been having issues with the left hand side, been thinking it was baring but Chris at Centerline in thomastown wasn't sure, said it might be tires as he was finding it difficult to get sound off the car when he lifted it.
Could that actually be apart of the problem?
It seems bizarre to me in the first place to put two rather different treads on either side of the car as wouldn't one side grip differently than the other?
I'm going to swap the PZ-Xs to the back tomorrow at my mate's as they seem to be in much better condition, the PZ-1s seem to be cracking at the edge of the treads.
Anyway, thoughts, ideas, experiences, insight?
Thanks,
Teir.
P.S,
If anyone generally knows what the difference between the Bridgestone Playz PZ-X and PZ-1s is that'd be good to know as well, they seem to both have rather different tread patterns.
https://www.sau.com.au/forums/topic/387766-different-treads-either-side/
I was under the impression that it's illegal to have 2 different tyres on the front? Or maybe that's on front wheel drives. And perhaps it would be better to put the best tyres on the front and the not so goods on the rear. Braking and steering is more important than going.
But hey... I'm still a noob.:rolleyes:
Edited by Not a Pulsar
oh that sucks....someone who owned your car in the past didn't give a shit about it :(
you definately want the same tyres on either side of the same axle....it might be expensive but I also always replace mine in pairs. The car must be consistent between left and right grip.
It wasn't the last owner, it was Pedders who put them like that after repairing some accident damage 6+ months ago.
I never realized because they have practically the exact same logos on them in the same spots etc.
It's a RWC requirement that each wheel on the same axle is the same make / brand / size / tread design. So, front tyres must be the same as each other, and rear tyres must be the same as each other, but front and rear don't have to be the same as each other.
Well then I've been driving risking a canary for the last 6+ months. Awesome. Thanks Pedders!
And to vareify as "Not a Pulsar" mentioned above, having a RWD would it be better to have the better looking tiers at the front or back? I was thinking the back as you want the traction on the running wheels.
OK. This is Australia, so we spell tyres with a y, not an i, and not as "tiers", which is the pulral of tier meaning "a level". Secondly, Better tyres alway go on the most important end of the car, which is the end that does the braking and STEERING. Thirdly, just pump them up to 34 psi and take it for a drive in the twisties. Then add 2 psi and do it again, then again. If it keeps getting better as you add pressure, then you should probably stop at about 38 psi. If it doesn't get better with more pressure, try less pressure. But FWIW, I generally use 32 psi or thereabout is normal tyres on boring cars, and upwards of 34 in good tyres on good cars. 38 psi in KU36s on R32.
I THOUGHT IT WAS TYRES! The f**kin auto correct kept disagreeing with me -_-
And I guess front it is!
As for pressure thanks for the tip, I'll start playing with it after I move them around. It's a 34 25gt but no one knows what the f**k the tyres are, if they're performance or not so just a matter of experimenting, thanks!
32 psi = R32
33 psi = R33
Front sounds like a good plan my man and if the bad ones are that bad, replace them asap and switch them all around again. ie new on front, old on back.
Also, since I can't find anything on the net and there's no markings on the tiers does anyone know what I should be pumping my tiers upto?
255/45/17 Playz PZ-1
255/45/17 Playz PZ-X
The tyre installer should be able to recommend the best pressure. FWIW, my local Bob Janes suggested I run 38psi my Falken ZE912s (235/45x17).
Not so in nsw, they only have to be of the same construction on each axle, either radial, or cross ply.
Treads can differ, its just highly recommended that you don't.
  • 4 weeks later...
I'm someone who even hates having different brands on different axles... Makes the cars wander around if there is the slightest difference in how the different tyres are made.
+1 here, you should always try and run the same tread all round. The reason being that having a space saver spare means at some point you will need to put a rear on the front because you shouldnt put a space saver on the front. This is also why mixed fitments is a dumb idea
