Im looking for a computer for my 32 Gtst but it is so hard to find anything that isnt a big $ racing set up.
I dont want to flash the chip cos its expensive in the long run (retune everytime i change somethig) and no handset with all the cool stuff on it.
Apexi power fc is what i want but its very hard to find, nearly got a new one from a bloke in japan, but it was put in some show car, so close yet so far.
Does anyone know about Link G4? They say i can get one but ive never heard of anyone using one on a 32 Gtst.
I think the motor is really lacking without it, considering the cams and turbo are upgraded.
https://www.sau.com.au/forums/topic/389128-32-gtst-needs-a-better-computer/
uh... no matter what ECU you have, if you make modifications you will need to have it retuned.
That is part and parcel of making modifications.
The same G4 plug in Link suits the R33 or R32 but Nistune will be a cheaper option. Any ecu needs to be retuned when you mod your engine.
If you have already upgraded the turbo and cams with the stock ecu not only are you missing out on the potential gains you are also risking your engine.
I think he was more talking about the need to pull and burn chips to achieve that retune, which is the most annoying part of chipped ECU tuning.
Hmmmm...
Well shes running rich and i never rev it over about 5000.
And i live in canberra so im limited to what the local tuners can tune, waiting to hear back from them.
I would pay for an apexi.
Well see about nistune.
Nistune.
and if you want to see a display - get an ecudatascan device.
I've got that combo in my R32.
http://ecudatascan.com.au/store.html
it can display like 10 or 12 parameters from an R32 GTST.
Also can be a GPS
and do lap timing for tracks and you can actually build your own track image in to it etc etc.
Cant get Nistune done here, i got quoted $3200 for a new Haltech setup with map sensor and tuned, im sure its good but too expensive for me. He also recommended bigger injectors, more $$$.
Maybe i have to take it to Sydney for a Nistune?
Is the Nistune up to the job? How well can it be tuned?
This is turning out to be much more difficult than i thought, so ill tell you whats on my car and maybe you (Sydney tuners) or someone you know can tune it properly.
R32 gtst manual (converted from auto)
Fmic
Rb25 turbo
Unknown cams (probably tomei poncams)
Pod filter
Cat back exhaust
Thermo fan
Should i get:
Split dump
3" cat
Adjustable cam gears
Bosch fuel pump
Or what bits do you guys recommend?
I would go to Sydney if ican get it done properly in one go. Want to do it ALL for under $4000.
as a guide.
my car has:
pod
turbo back exhaust
fuel pump
15psi on stock turbo
nistune
makes 160rwkw
so with an RB25 tubo you'll get around 10-15% more at the same boost (roughly)
not sure how much difference the cams and cam gears will make.
Definitely finish off the exhaust and do the fuel pump.
I don't think it will need bigger injectors if the turbo you are going to use is an RB25 one.
nistune is up to the task mate.
in some ways, more so than a PFC.
Canberra is only like 3 hours away from sydney
organise a day with a tuner and drive down for it.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
