Import Monster Sauvic Deca Motorkhana - 2012 Round 1
Proudly Presents:
Import Monster SAU-Vic DECA Motorkhana ROUND 1 of 4 of the 2012 DECA CHAMPIONSHIP
When : Saturday 25th February 2012
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. HERE!!!
NO PAYMENT, YOU WILL NOT BE ON THE LIST
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Ryan Bell Disclaimer'.
Event Schedule:Here
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 20th February.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
  • Replies 378
Entry List:
1. Ash Cosgriff R33 GTR
2. Import Monster
3. Leon Stapley 180sx
4. Ryan Bell 180sx
5. Ashley Stacey R33 GTR
6. Luke Schulze R33 GTS-t
7. Trung Nguyen Chaser
8. Chris Taylor 300zx
9. Daniel Taylor S14
10. Harsh Gupta R33 GTR
11. Bradly Insley XR6
12. Mark Ryan R33 GTS-t
13. Hamish Hampton R33 GTS-t
14. Clive Small Lancer
15. Jake Lowry S14
16. Paul Stephenson EVO VII
17. Kat Glebova EVO VII
18. Mario West EVO VIII
19. Jett Benson 180SX
20. Simon Henman R33 GTS-t
21. Gary Swift 180sx
22. Sandeep Abeywickrema 300zx
23. Alex Skrekovski EVO X
24. Steven Skrekovski MX5
25. Russell Cunningham R32 GTS-t
26. Jordan Sudarevic MX5
27. Ryan Gorzella RX8
28. Rhys Cantrill R33 GTS-t
29. Daegal Harris S14
30. Johnathon Oliver VX
31. Jakub Radzikowski 180sx
32. Brad Archbold Evo VIII
33. Thai Long Chieu Corona
34. Jad Luciani R33 GTS-t
35. Matthew Nisi S14
36. Daniel Somerville STI
37. Andy Theobald GSR
38. John Packham S14
39. Elvis Ayala R33 GTS-t
40. Laith Graham R33 GTS-t
41. Brendon Pryor R33 GTS-t
42. Damien Nebel STI
43. Mark Rodgers STI
44.
45.
46.
47.
48.
49.
50.
Reserve:
1.
2.
3.
4.
5.
Can I enter in a Daihatsu Terios? It's designed extra narrow so it can fit down certain streets in Japan, combine that with its high center of mass and it'll be great on the skidpan! Lets not forget the 65kw at the fly + AWD for some limiter launches!
gonna shoot some money through and my entry tomorrow or monday :)
i hope the NA can actually do something haha
N/A's kill it on the skid pan.... soooooo much easier than high HP cars
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
