no you dont need r33 axles, i'm running gtst r33 axles in my daily cefiro with the s13/r32/a31 type subframe in there so they should contract and expand to suit, which is just what they do if you have a spare set laying around to look at.
r32 LCA's are slightly shorter and the bushes are slightly thinner then r33 so that might be why its suggested also the camber arms line up the same they just might be slightly longer as i have a few spare sets laying around that i compared.
the r32 tie rod could be shorter and the hicas may not mount up to the same hole so i'm unsure those issuses
^Thanks, mate. That was the last bit of information I needed.
I haven't yet installed the R33 subframe but it looks like I just need the items I previously mentioned and I can still retain my BNR32 axles.
I'm going to uninstall the HICAS at that time so I just need to figure out if I can use a HICAS lock out bar designed for the BCNR33. I imagine that BCNR33 lock out bars will suit me better than ones designed for the BNR32.
Don't use a HICAS lockout bar. Get one of the kits that pisses the HICAS rack off (and doesn't replace it with a bar) and instead adds some brackets to mount some new toe arms to completely get rid of the old tie rods. The tie rods are half the problem with old HICAS rear ends. They get sloppy. Why keep that crap in the car when you can get rid of it.
I went the whole hog and put a non-HICAS subframe into my R32 (GTSt) rather than have anything non-factory back there. That's because technically any HICAS removal/locokut is modification of a steering system and must be engineered or it is defectable.
My car just went through Regency like this for the engine conversion and the inspector (who knows Nissans fairly well because he's probably been under 50% of the S13s and R32/3s in Adelaide!!) did not even blink.
Thanks for the advice. You're non HICAS subframe is definitely non factory back there.
I'm changing the engineering of the rear anyways per the use of a different subframe. I doubt installing a HICAS lock bar.. Bars will cause more major geometry changes than I will already have.
Btw, I'm using SPL Hicas lock bars as opposed to a long bar.
No....my non-HICAS subframe is from a Cefiro but is exactly the same as a non-HICAS R32 subframe. There were plenty such cars made, just not as GTSts. So it is definitely factory. Factory subframe, factory toe rods. Unless you 100% were expecting to find HICAS under there, you wouldn't even blink. But the SPL bars look non-factory even though they approximate the same design as a proper non-HICAS subframe. If they are brightly coloured, paint them black before you fit them.
I don't worry about the geometry changes and so on that result from mods (unless they are undesirable changes from poorly thought through mods!! But let's assume that we're talking about intended geometry changes). I do worry about keeping it looking stock enough that no cop will bend down and jump for defect glory joy if he gets a hard on for me.
yes non hicas frames came from nissan and the a31/r32/s13 frames are all the same except for an extra exhaust mount on the s13.
gtr cradles are ment to have some extra bracing but nothing special as that can be welded to the others.
i'm just going to make up a mount out of plate and weld it in for the hicas r33 cradle i have for my non hicas ceffy.
edit: in fact s15 cradles are said to be the same as the r33 but the s15 were all non hicas
Edited by Dan_J
My point, and maybe I see things differently, was that a rear subframe other than stock is not "factory."
Great, yeah, its from another Nissan vehicle. Perhaps, that's "factory" according Aussie laws.
A subframe from another make could have hypothetically fit on there and been "factory" for that specific make. For example, lets say that a Ferrari subframe fit on there from the Ferrari factory.
Anyways, I get the point. I love the idea of not having to use hicas lock bars if not needed. I've been told that the R33, S14, S15 are basically the same.
  • 1 year later...
I had mine done a while ago, Brad/Risking did it for me just before I busted my engine so I cant tell you how much better it makes the car..
didn't end up costing me that much in the end, I did it as an upgrade while I was changing my subframe and diff bushes.
How did you manage to fit the 33 frame to the 33?
When the 33 frame is fitted what suspension and brakes will be used??
When u want to fit after market parts how do you go about that ??
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
