I came across these on good ol ebay recently, just wanted to see if anyone has used one before or get opinions or to be more to the point, see if there crap. im not planning on putting one on my 33 but maybe another 4cyl turbo in the near future.
http://www.ebay.com.au/itm/OBX-BILLET-INLINE-BLOW-OFF-VALVE-BOV-2-5-PIPING-Black-/180807013295?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a18f013af#ht_1649wt_1163
https://www.sau.com.au/forums/topic/389793-inline-bov/
True, i had a turbosmart bov that was grub screwed, it never leaked, from what ive read on these, they cant be used with a maf sensor cause the valve comes open on idle then as soon as theres any drop in vacuum the valve shuts, sounds like no one has used one before ?
Heres one in action.
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6209926
Wtf, it opens on vacuum? Won't that cause unfiltered air to get into the engine? The fact that it opens on idle isn't a problem in a maf setup, you can run your maf in your intake pipe and have this infront of that. The main issue I would be concerned about is shit getting in there. Off boost is fine as air will be gushing out and it will snap shut as soon as its vented, but opening on idle?
Edit: I'm confused as to how this works. Vacuum line goes in the back. When there is alot of vacuum the unit pulls it self back to release boost. When it is on boost, the vacuum line feeds the pressure to the back of the ring valve thing to keep it shut. Won't the springs keep it shut while you are just cruising around? If it didn't cost so much, I would buy one to tinker with and have a fiddle with to see how it works. Its pretty stealthy. You can fit it in line in your cooler piping anywhere in your front bar.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6210105
In regards to the bov open on idle....just thought I would throw something out there, could be completely wrong..... but from memory, someone on here yonks ago was talking about most bovs not working the way they should.
they said bovs should leak a bit on idle and what that does is encourage the turbo to start spooling earlier as it is trying to makeup for the lost vaccum? when it starts boosting it holds shut until full boost etc and then release.... but that was with a traditional bov and I cannot remember if people agreed or disagreed...
is an interesting design though, I like the stealth applications you could use it fo, whether or not its effective though..
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6211711
I think this is true only with the standard BOV which is open all the time off boost. Problem is you will have unmetered air being sucked into the engine or lost which will both cause a car with an AFM to run like dick.
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6211719
What is wrong the stock one?
This has all the same problems as an aftermarket venting to atmosphere bov and no advantages of the stock one. Bin it.
This is for people who want an aftermarket BOV which vents to atmosphere, running a MAP setup, to hide this thing somewhere in the front bar so that it can't be seen and still have the stock BOV in place, plumbed in place but doing nothing.
Its not for many, but the idea is interesting. They should build a wastegate which works the same way in the exhaust. Then again, anything attached to the exhaust always looks sus.
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6211799
or just just the stock bov with a MAP, I don't know why people have a hard on for removing the stock one, it works great.
Using something similar on the exhaust for a wastegate would be interesting but you'd need to shield it, otherwise you'd just have a hardcore exhaust leak in the engine bay cooking everything and if you shielded it you'd have to seal half it off so it wouldn't be as effective.
Edited by Rolls
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6211823
Design a longer unit with longer ports which you can face towards the ground, but yeah you probably don't want raw exhaust flowing in your engine bay haha.
This thing gives the atmo sound some people like so I guess its stealthy plus noisy, even though I do get a pssh from my stock BOV with a pod.
https://www.sau.com.au/forums/topic/389793-inline-bov/#findComment-6211850
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
