"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
  • Replies 384
Kam, any chance you would be considering a low mount manifold?
There is a distinct lack of affordable (same price range as your high mounts), available (HKS items are rather hard to find), low mount (put the turbo flange in same position as stock manifold does) exhaust manifolds..
Kam - Do you make a low mount option without a wastegate mount?
For RB25, using internal wastegate Garret turbo.
I would also like to know if you could make a manifold with an alternate flange plate?
IE I would like an SR manifold in highmount design but with an EVO flange plate.
Would love to know and asap :)
What power have pepole made with these ?? Anyonr made dececent power ?? Hoping to push 300 plus with 44mm gate
Guys, If anyones after a genuine HKS RB26 Low Mount T4 manifold and matching 1bar wastegate, I have a brand new, unsued one for sale...PM me??
well im doin 355kw with a shit chinese manifold... so id assume ud do the same power if not more on one of these
Hi guys,
Sorry we have been flat out,
As for the low mount manifold i don't think we will be making them as the demand is not very high and last time we did it sat with us for months.
I will be making some new manifolds in the next few weeks,
1) No WG port option (so you can run direct off the back of the turbo or if you have a internal gate )
2) the Collectors will be smoother and will have a better flow we already have some ideas,
3) Exhaust flange will be machined after and checked with a straight ruler for no gaps,
4) 2 options 44mm / 50mm waste gate option ( would any one need a 60mm option ? let me know prior)
Any more info or adjustments let me know !
Regards
Kam
38mm options already in stock,
Who else would prefer 40mm over 44? let us know what you guys want so i know what to make for you :)
Thanks
just want to point out that this weld while it looks nice and pretty is NOT a strong weld. theres a large amount of undercut on the edges. needs more filler wire as it loks like its just been fusioned together
I regards to kams manifold seeing my mate bought one and is currently using it has been long before this thread started i can say that his.setup on a stock rb25 with gtx3076 works fine straight of the gate holds 14psi no problems no boost creep he is running a 50mm tial gate currently and makes 260 rwkw safe as its a drift car and he is very heavy footed.it did make 295kw at 17psi but was taken back to 14psi till he got more used to the cars setup
Hi guys,
Regards
Kam
Pity :/
Kam, i want one with a 44mm V-Band Wastegate outlet, with 44mm ID wastegate pipeing too and your new improved ported merged collector, T4 Flange. Please drop me a PM on here with the price and leadtime bud?? Cash waiting plus if the manifold is good Ill do a full writeup for you on the UK GTR Forums!!! Cheers, Andy
Just a point too........anyone running a RB26 or bigger with T4 framed Turbo should have a 44mm wastegate as minimum in my experiance.....im guessing thats why "other" manifold manufactures build with 50mm dia wastegate tubes and flanges??
I've got cash to purchase one so ounce uve made the new manifold I will purchase one with 44mm gate
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
