"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
  • Replies 384
Just google image Rex Kelway manifold.
I currently run his low mount manifold on my SR but getting him to make a high mount T3 external gate manifold in the next couple weeks.
Edited by slippylotion
i forgot we gave a shit about SR manifolds..
Forgot I gave a f*ck about you, ya clown.
He was talking about SR manifolds!
But hey, if all you can afford is these manifolds, go for it. I know Id spend the little extra for a lot better quality.
How is it that the SR manifold is fkn rubbish and if I got something like that I would throw it into the Tasman but the RB manifold just above looks half ok
cause SR's are useless junk like 1J's :P
and I have found a few rex kelway manifolds for rb's but have no idea how to get in touch with him, but this isnt the thread for it..
Keep up the good work Kam, If I can ever go highmount ill be sure to look here
PM sent with his details.
i thought you were cool man :down:
too many haters in this thread. period.
lol my easter will be spent stripping a 180 back to stock from a built motor with a 3071r.. Im not even being paid so fark the farking SR :rant:
clown? haha.. go away with your shit sr and your kelway manifold mate no1 gives a shit. go hate on manifolds in a different thread u big high roller.
lol an hours work man, i am the SR specialisto'
why does everyone keep comparing this guys manifold to others that are 4x the price or more... its like nobody can appreciate a bargain.
if i were crans id be stoked with that manifold, and laughing at people who paid 4x that
+1. Pending results they look like great value so far, i'd certainly be keen if i was looking for a high mount manifold.
Stoked with a manifold that's no better than a cheap china stainless item. IMO these look really bad and I wouldn't use one if I was given it but that's my opinion.
Why are you guys using them beside being cheap?The only gain I see you getting is being able to say you have a steam pipe manifold but NOT a quality built manifold!
Now sits back and awaits the b*tching instead of people listening to an opinion with out taking offense!
look champ, everyone knows the china SS actually do a decent job. the problem is not their performance, its their strength.
if you can buy a decent manifold that will work and wont break for a good price, why not?
the man is selling his product for what it is. hes not trying to sell a T4 TS manifold that will out perform the competition.. making an open frame housing is no secret science,especially at the 300kw most people will use these for. let it go.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
