Hi,
I need to install a new double din headunit to replace my R34 factory unit. After reading through the forums, it seems relatively simple to remove the unit however there replacing the wiring loom is beyond my mechanical abilities!
I know that JB, BDL, Braddon and Tuggeranong car audio do instllations around town. If there are others installers that people recommend, can you let me know?
Thanks
Nick
https://www.sau.com.au/forums/topic/392219-car-audio-canberra/
If you're looking for a professional install (not DIY) head to see Warren at BDL car stereo in Fyshwick. If you like, you can tell him that Anthony Spink referred you and he will look after you, they are the best installers in Canberra, high quality of workmanship.
http://www.facebook.com/bdlcarstereo
If you check out their page they have a lot of pictures of installs they have completed, as well as some of their demo cars.
x11ty for Wazza! He's my mate and you can name drop me as well if you want haha
They did my security system and i was not happy. my boot was not locking properly and most of the screws were missing when they took the dash out, didn't put back all the screws in. elite car sound & vision in belco installed a sound system in my cousin brothers car for $3grand and he is happy with the work they did. so if you want give a call to them as well
BDL Fyshwick have done all my Alarm systems - No complaints.
Audiotech - tuggeranong have done 4 full stereo systems - No complaints
Audiotech did my Double din HU and speakers in the 34 12months ago - all is good
They just did my R32 GTR about 2 months ago.
and last week I got them to replace the Airial Amplifier and earthed it, and Connected airial to AC to fix an inherint problem with all R32's radio reception problem.
As Ive used Tony (Audiotech) alot I get taken care of pretty well.
Cant go wrong with either shops. With using a shop you can go back and have it fixed. In DIY's your left wondering if you get it wrong.
Harder then to take it to a shop to resolve any issues.
I'd take it to Warren BDL Fyshwick if your new, These SAU guys dont praise easily but rag on shops pretty quick if there not happy.
My 2cents worth
*edit* I would never use JB.
+1 D.I.Y milk
Nissan adaptor harnesses are good.
I used a maxima one in my xtrail and it was sweet til I upgraded again but then I just modified the adaptor harness to suit. It left the standard harness unbutchered.
I just put a double din screen in my stagea and the last single din kenwood unit had been "professionally installed" (just before I bought it) with rounded screws, and 2 reels of electrical tape on poorly soldered connections. Not to mention hot glue gun'd and chopped up metal housing that secured the unit.
Wazza really gets around lol.
Also, yeah get a wiring harness and do it yourself or get verms to show you. It is not worth getting a shop to do it, you need to learn more bout your own car and how to do a basic head-deck change over.
If you have a skyline, it will need work and maintenance... Unless you are made of money learn and do the little easy bits yourself and if you get offered a hand from a SAU pro, dont waste the opportunity.
Its really easy to do and on the skylines there is heaps of room behind the standard head decks!
You can either get a wiring harness which we can wire into the new harness and then you can put the standard head unit back in!
Either way wont take long and soldering the joins makes a perfect connection!
Yeah, not hard to do at all. I've done head deck, sub + amp install and a full car PC in my car not too long ago.
If you decide to forego the harness (it does make it way easier as you can revert back to stock deck or change later on without needing to butcher your wiring loom too much) then pretty sure this wiring guide will apply to you http://www.installdr.com/Harnesses/Nissan-Wiring.pdf Just match it up to the instructions that come with your deck and you'll be set.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
