Pretty much self explanatory I think. Timing belt is well overdue, and I would like to know what brands I should be looking at for a quality belt/kit. Found a few on ebay. What are people's thoughts?
NISMO with water pump: (price looks a bit steep to me though) $490
http://www.ebay.com.au/itm/NISMO-TIMING-BELT-SERVICE-KIT-100-000KM-SKYLINE-GTR-CEFIRO-STAGEA-RB25-RB26-/220893533016?pt=AU_Car_Parts_Accessories&hash=item336e47d358
Bando/NSK?? $170
http://www.ebay.com.au/itm/NISSAN-TIMING-BELT-KIT-SKYLINE-GTR-STAGEA-CEFIRO-LAUREL-RB20-RB25DET-RB26DETT-/220872048960?pt=AU_Car_Parts_Accessories&hash=item336d000140
Greddy/Trust $310
http://www.ebay.com.au/itm/GREDDY-TRUST-TIMING-BELT-KIT-SKYLINE-GTR-STAGEA-CEFIRO-LAUREL-RB20-RB25-RB26DETT-/220865648772?pt=AU_Car_Parts_Accessories&hash=item336c9e5884
or should I go to nissan dealer directly and get a genuine kit??
https://www.sau.com.au/forums/topic/392860-good-timing-belt/
I put a Gates Racing belt in my R33. It's a little noisy (might be over tightened) but works well
Got it in a kit from kudos motorsport
http://www.kudosmotorsports.com/catalog/nissan-100000km-service-kit-water-pump-timing-belt-nissan-skyline-r33-gts25t-rb25det-p-558.html
OEM timing belt is fine, The gates belts have the tendency with the blue plastic coloured coating to flake off after time which gets under the timing belt and causes belt slip. The OEM belt is good for 700hp + proven from my understanding, Gates belts are a bastard to get on and off.
OEM water pump is also fine if your really concerned i purchased a N1 water pump for my RS four S which is currently in it now with new NSK bearings, I believe that is Nissan's OEM bearings.
This is the kit you will be needing Jeremy.. http://www.kudosmotorsports.com/catalog/nissan-100000km-service-kit-water-pump-timing-belt-nissan-skyline-r34-25gtt-rb25det-neo-p-91.html
Edited by hks33
+1 OEM, why stick a whining belt on your car?
ebay seller performancenissan is hard to beat for a full OEM 100k service kit.
'cos it looks fully sikker when u got klear coverz. Nooooo! :)
+2 Gates - I went for the whiney racing belt. The whine is almost gone after 20,000k's and i liked it anyway ( something wrong with me ?) . Why not get a stronger/higher temp belt for same money as a OEM ?
Because the OEM belts aren't as prone to slippage as opposed to the OEM belt, They are good for 700hp + so unless your making huge power figures i would not worry.
How can you rate a timing belt for horsepower? Tensile strength; Yes. Horsepower; Nope.
The only things that will stress a belt are; heavier than stock valve springs, or cams with more aggressive opening ramps. The power that the engine produces is irrelevant to the belt.
The slippage that you speak of; where does this happen on synchronous belt? If the belt "slips" it has teeth missing; no other way it can slip. It's not a bloody fan belt.
If the belt jumps a tooth; it isn't tensioned correctly; or has stretched, and broken the internal cords, and is about to fail catastrophically.
IMO, there's absolutely nothing wrong with OEM belts, most of what you're fed on "High Perfomance" belt is marketing hype.
Edited by Daleo
Easy... Guys interstate and overseas are making 700hp+ with OEM belts, Speak to "Ashley Hobson" at classic performance dyno tune works on RB's all day in and out and he's seen everything, Read it even here myself on SAU so it must be saying something.
Been told from my sources as well its not just the one place I've heard it from and i can definitely see some logic behind that.
Edited by hks33
I'm not arguing that an OEM belt can't support 700HP; I'm saying that the timing belt doesn't carry that horsepower. Rating the belt for horsepower is irrelevant. The crank pulls on the belt, which turns the cams; not the other way around.
We seem to be on the same page with the OEM belt strength situation.thumbsup.gif
Say you had a hypothetical GTR producing 500HP, and you change to a larger turbo set up; the car now produce 700hp; you haven't changed the rev limit or the cams; only tuning and turbos.
The belt is not under any more stress than it was when the engine produced 500hp.
The power of the engine isn't dictated by the belt; nor the life or strength of the belt dictated by the engine power.
Edited by Daleo
your right Dale ,horsepower doesn`t mean diderly shit, all comes down to the tension on the belt, pulley condition , tentioner alignment and age of the belt. I bought a couple of Japanese belts of Ebay,good quality and reasonably priced, cant see any reason to change the water pump because it was perfect. Guess it depends if you do your own work or pay someone to rip you off. did the whole job in under 2 hours, amazing how quiet it is now though. one thing to remember , not all belts have the same profile,hence the whyne? which means incorect fit and probable failure.
ok thanks guys. will probs go the kit through kudos. is there anything special i need to know? other than removing all old water pump gasket to get good seal and not turning any parts of the motor while the belt is off. and is there any special tools i would need? apart from the new gasket goo, and a socket set?
Edit: speaking of which what is the best way to get the old seal off??
Edited by Pft shh 89
You'll need a puller for the harmonic balancer.
Even if you buy a super duper twice as expensive belt its still going to be changed at 100,000km anyway.
There's a full how to in the DIY sticky at the top:
http://www.skylinesa...y-new-cam-belt/
the stanley harmonic balancer puller that supercheap sell was a little on the big side, none of the bolts fitted and it only just fitted on and was really close to the back of the radiator support thingo/aircon condensor
As per SKs tutorial you can use the two top bolts from the cam cover with a couple of washers.
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
