My car has lost about 85hp at the wheels, thought the motor was getting sad, but got the leak down test an compression test done both came back fine. tune still seemed good just missing power (from 385 back to bout 300)
wondering if anyone had any ideas wot it could be? thank in advance :thanks:
https://www.sau.com.au/forums/topic/393002-wheres-the-power-gone/
Might get them to pull the exhaust off an see if it makes any difference, could be possible.. tho is there much to collapse in a 3inch metal cat..they are nearly straight thru. Wot could get stuck in the intake? hopefully the air filters get rid of anything big enough to clog an intake pipe. Dont think it would be fuel cos its a noticable difference on the road an it just dont go as good as it used to, an was the same dyno. but will get them get them to check out the exhaust. the turbo's are bout 2-3 years old garret think they're -5's running 20 psi is it very common for turbos to shit emselves or something cause them to run inefficiently?? Havent eva noticed any wierd noises when boosting. just dont seem to get the effect they used to give. something seems to be choking the engine somewhere.
lol I pulled my intake apart on my 32 for shits and giggles and found my missing 13mm spanner in the BOV return pipe??? !!!!
85kws is a big lose, maybe a hole in the intake pipeing or small hose come off, any black smoke under full boost?
Depending on your set up - oiled up AFM's will have that effect. If you are running a recirculation system for blow by gases and it is leaking oil out the bovs (common on GTR's) or you have re-oiled a foam air filter there is a fair chance the AFM's are messed up.
This causes them to read high - the consequence being single digit AFR's, less ignition advance and no horsepowers.
If you had it on the dyno what are the AFR's?
have got a vipec ecu so no longer use the z32 afm's (i should pull them off an sell them..if they're worth anything 2nd hand.)
Car was dyno'd this afternoon, an mechanic thinks its a clogged exhaust. so they gunna take the cat out in the morning an re dyno it to see if thats the prob
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
