Alright who's going?
http://forumbattle.com.au/
Saturday $37.50
Sunday $37.50
3-day $73.50
3-day seating $160
Serious SAU cars turning up.
So instead of bitching and moaning about it and spending the day at home letting your mum braid your hair, get the fug along!
I'm going Sunday.
The pictures on the Advan Yokohama site are a little out of date, so the mandatory carbon teaser pic...gallery_709_1130_297743.jpg
Also see BIG RED & Adam in action @ Calder Park!
Chris - R34 GTR
Stephen - R33 GTR - Yes those are twin 3037 high mouts :wub:
Dennis - R32 GTR (Competing in Street Class)
Anthony - R34 GTR
Last, and by no means the least... These two awesome machines.
Gerry's awesome C110
& Gerry's brother happens to be bringing along one for good measure!
Stefan - R32 GTR
Jonno - R32 GTR
Derek - R34 GTR
Scott & Johns R32 GTR (Winfield Replica)
Daniel - R34 GTR
Marc - DR30
https://www.sau.com.au/forums/topic/393062-forum-battle/
  • Replies 40
Any more info on this?
Youtube "BIG RED", or just look on the main SAU News page, has links embedded.
Lot of work gone into it over the past 4 weeks to have it ready for this weekend, and still lots of work to go :D
Paul - best day for racing stuff (forum wise) is Sat.
Sun everyone is stationary. But there will be other ARC stuff going on so Sun might be better for that?
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6254241
Ah crap. I'm freakn working in NSW on Saturday. Fark!
Ash what are the Media requirements for this event? Is SAU allowed to GoPro up and publish on YouTube?
I'm just thinking Laith may want to drop some of the video into an SAU VIC TV ep.
I can charge up the GoPro's and set them to auto record when on, easy to use. Surely we need incar / oncar of SAU smashing the rest of the competition?
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6255273
John - NFI about requirements/restrictions.
Will be in Cheltenham till late. If you wanna drop them off i can just try organise whatever i can on the day.
Charging them I can organise tonight @ home.
Regarding S'n'S - Does anyone know if the cars need to stay at the venue the whole day? Or can we leave anytime after the judging?
Far as I know you have to wait until the end as we are in the middle of the Dome... You can't just up and leave when you feel like it.
However feel free to contact them directly if you need more information - they put contact details into their email on Wed or Tues.
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6257110
checked with Sean re moving cars for SnS, as long as you're in by 9am and he hopes to have the judging and what-not done by lunch-time, you're free to come and go (this has been helped by the change of locations away from the thunderdome, so they don't have to worry about rally traffic). So yeah, that's good, because i gotta be at work by 2:30! hahaha :D
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6259102
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
