Alright who's going?
http://forumbattle.com.au/
Saturday $37.50
Sunday $37.50
3-day $73.50
3-day seating $160
Serious SAU cars turning up.
So instead of bitching and moaning about it and spending the day at home letting your mum braid your hair, get the fug along!
I'm going Sunday.
The pictures on the Advan Yokohama site are a little out of date, so the mandatory carbon teaser pic...gallery_709_1130_297743.jpg
Also see BIG RED & Adam in action @ Calder Park!
Chris - R34 GTR
Stephen - R33 GTR - Yes those are twin 3037 high mouts :wub:
Dennis - R32 GTR (Competing in Street Class)
Anthony - R34 GTR
Last, and by no means the least... These two awesome machines.
Gerry's awesome C110
& Gerry's brother happens to be bringing along one for good measure!
Stefan - R32 GTR
Jonno - R32 GTR
Derek - R34 GTR
Scott & Johns R32 GTR (Winfield Replica)
Daniel - R34 GTR
Marc - DR30
https://www.sau.com.au/forums/topic/393062-forum-battle/
  • Replies 40
Any more info on this?
Youtube "BIG RED", or just look on the main SAU News page, has links embedded.
Lot of work gone into it over the past 4 weeks to have it ready for this weekend, and still lots of work to go :D
Paul - best day for racing stuff (forum wise) is Sat.
Sun everyone is stationary. But there will be other ARC stuff going on so Sun might be better for that?
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6254241
Ah crap. I'm freakn working in NSW on Saturday. Fark!
Ash what are the Media requirements for this event? Is SAU allowed to GoPro up and publish on YouTube?
I'm just thinking Laith may want to drop some of the video into an SAU VIC TV ep.
I can charge up the GoPro's and set them to auto record when on, easy to use. Surely we need incar / oncar of SAU smashing the rest of the competition?
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6255273
John - NFI about requirements/restrictions.
Will be in Cheltenham till late. If you wanna drop them off i can just try organise whatever i can on the day.
Charging them I can organise tonight @ home.
Regarding S'n'S - Does anyone know if the cars need to stay at the venue the whole day? Or can we leave anytime after the judging?
Far as I know you have to wait until the end as we are in the middle of the Dome... You can't just up and leave when you feel like it.
However feel free to contact them directly if you need more information - they put contact details into their email on Wed or Tues.
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6257110
checked with Sean re moving cars for SnS, as long as you're in by 9am and he hopes to have the judging and what-not done by lunch-time, you're free to come and go (this has been helped by the change of locations away from the thunderdome, so they don't have to worry about rally traffic). So yeah, that's good, because i gotta be at work by 2:30! hahaha :D
https://www.sau.com.au/forums/topic/393062-forum-battle/#findComment-6259102
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
