Swap N1 R34 Gtr For R35 + $$
ask Bobby how much he had his advertised on ebay for lol
($1M - im sure he didnt sell it for that much though)
Luckily, I believe eBay have a cap on the final value / listing fee for vehicles.
Otherwise, that would have been an expensive bill.
Edited by iwanta34gtr
For a quarter of a mill thats still represents good value for money for a super car imo. Would still beat a lot of cars today. I wonder if the owners drive them much or if they have them as a collectors and keep them in storage.
well theres only 19 of them so i'd be pretty careful. Its rarer than a lot of higher-end hypercars that cost many times the cost of a Z-tune (AM One-77 springs to mind).
I know in Japan you sometimes see one at those Daikoku Futo meets so they do get driven, but imagine if you owned a car that was 1 of 19 in the existence. you certainly wouldn't drive it everyday. i might make an early morning breakfast run on the sunday though.
Just saying...
But let say if a Nismo Z-Tune did go for a 'Super Car' Price... I still couldn't justify it.
Sure, you'd own 1 out of the 20 that were built but if you take a look at the car, Nismo just made it special from a handful of 2nd hand V-Spec's.
I am aware that an extensive amount of work went into building the Nismo Z-Tunes which has Super Car performance.
My point is, if you had the cash, you'd buy a Base model R34 GTR and work / customise to how you'd want it and still have Super Car performance.
In having said all that, no doubt, I would still own a Z-Tune :)
But your super car performance base model R34 GTR would not hold the same value as a ztune, not even close.
Clear examples going through the for sale section here, cars with 100K+ work, sell for less than 100K.
I should add that a lot of these cars that are built, are faster than the ztune in at least one way or another.
Most of the people who can afford a ztune, aren't buying it to be able to drive it around the track.
Well thats what I believe.
Nismo Z-Tune only holds a higher value because of what Nismo did to it.
So would you pay for performance or for 'name' sake..?
Garage queen? :laugh:
Imaging owning a car thats only going to appreciate in value thats win win. You ever need to sell your worked up vspec you will never get your money back. At least with a z tune you can enjoy super car performance and at a minimum break even if your unlucky enough to sell it.
If I had one the most driving it would do is an occasional late night drive and a track day here and there to really enjoy the performance of it
Yeah, thats the truth. Only cause Nismo touched it thoroughly that it is worth so much.
A car with performance and has the ability to appreciate is a win for me. So in this case, the car does perform and has a name and the added bonus of appreciating value.
Garage queen, in a lot of ways yes.
But I reckon a ztune with 200000km would still be worth a lot haha.
Terry, how long ago was this? Just trying to scope a timeline for the 65% appreciation.
Forget the Z-tune - lets start talking about the KPGC10 coupes - how many of them are in Oz, and how much would they be going for?
I thought they were more expensive than this
Just needs the front diffuser
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=280854798483#ht_1965wt_1396
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
