When: Wednesday, 21st March
Where: Garage Cafe
221 Berkeley Street, Melbourne VIC 3000
(03) 9349 5000
Time: 7:30PM
Pretty simple, come along to catch up and talk all things SAU. Find out what events are planned, who else is running events and suggest things the committee should be doing to make the club a better place!
https://www.sau.com.au/forums/topic/393293-sau-vic-meetup/
  • Replies 59
21 Wednesday Wednesday – SAU Vic Monthly Meet - Garage Cafe
from the events calendar
food was good last time so I'll be there
might bring the nissan as well this time so I know it's charged for that weekend..
mmm track day
https://www.sau.com.au/forums/topic/393293-sau-vic-meetup/#findComment-6255442
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
