  • Replies 150
G'day C yar,
Perth is easy. I send them out COD post, so you only have ot pay for them when you pick them up - much safer this way. Nation wide postage is only $11. So the total cost will be $65 for the boot set, and $12 postage, totaling $77.
If your interested then I just need some sort of postal address (send me a PM with an address) and I can get a set out to you first thing Monday morning.
Any questions just ask away :P
Cheers
J
i just put in the boots and they are excellent. had a bit of trouble with the metal ring thing in the shifter which holds the boot in place. is there an easy way to make it sit properly as the leather (very nice) is a bit thicker than the old vinyl boot?
thanks again jay, they are must haves for all skyline owners (vinyl ones are crap!)
LOL - yepp, that metal ring is mega MEGA tight. Best thing to do is to (if you get stuck) is to pry the ring open just a touch - not much at all, but just a little bit.
All of the installs I've done I've been able to get the ring to sit right, but like I said, it's MEGA tight.
Glad you guys like them :)
J
hey what and where is the wire frame for the gear stick bootie supposed to go? I don't think I even have a wire frame - the boot is all soft and mushy. Could explain why the top of the bootie sits so low.....
Anyone know where i can get a wireframe from?
King-kw13 - the wire frame sits right down the bottom of the boot and clips into the centre console from underneath.
You won't be able to see it from up top though.
Best thing to do is take the centre console out and have a gander and see what the go is.
J
  • 3 weeks later...
Hey Jay,
Just got a new gear knob to replace the old worn one and now the gearstick and handbrake boots look out of place.
Can you put me down for a set please.
I can come and pick them up from you when they are ready.
Cheers.
Originally posted by FunkBrother
Hey Jay,
Cheers.
No problems - I'll be ordering the new hide this pay day (thursday), so the next lot should be ready in about 2-3 weeks.
Seems your in canberra I can install them for you too. I've got it down pat now, takes me about 30 mins :D
I'll drop you a PM when they are ready.
Cheers
J
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
