your welcome Kozi
glad you had fun Allen
Great to hear guys had a blast - sadly I didn't make it at all as work went crazy and time well and truly got away from me :( .... I was busting to go for a passenger blast in Munro's R35GTR or Daniel's Radical as well :( .....
(Insert User Name Here) remember that most SAU:SA track days are not opened up to the general SAU community, so if you want to be guaranteed on future days you gotta join up :) ..... it is cheap and easy - and membership has it's benefits :D
www.sausa.com.au
for a fee of $35 and a once of administration fee of $15 we are the cheapest CAMS affiliated club in Australia, for that you members discounts at Willall Racing, Main North Nissan, Auto Barn - Mile End, Blackwood Tyrepower and various other places quickly see's your membership pay itself off
  • Replies 80
Posted Images
awesome day lads! Thanks to all the SAUSA guys that put in the effort to organise it. Passenger laps was a good idea! The S14 was only a second slower with the wife in the car 1:19.3, pulled a best 1:18.3 for the day (best optimal time was 1:17.77, best splits for the day combined). Definetly need some new rear tyres and a play with the wheel alignment settings though!
was wondering where you were, how's the car coming along?
Bloody work mate. Car is with another SAU member getting ready for the defect to be cleared. Once that's done, should be keen for the next track day.
Hey all
I took a little footage in the morning and made a quick vid.
New camera first time out with it, tried to get some practice in. long way to go lol
Mainly wanted to get my head around it before a holiday I'm off on, and sorry about my lack of editing skills.
Great pics!
I'd like to thank Adam from Holeshot and Luke from LTM for coming down for the day and being "official" SAU:SA photographers! Now support them guys and go buy some prints of the shots they have taken
Absolutely speing I couldn't make it for this one guys - same as a few others I was smashed with work and just couldn't get away :( .... I wasn't looking too bad, but then at 11am everything went haywire and I knew I was screwed for the day.
Looked like eveyone had an amazing time!
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
